CAJW
Jun 02, 2019Explorer
Camco EAZ Lifts are rated at 5,000 lbs. per pair, so yes, you should be fine using those for temporary support, but as noted above, using a wider board (i.e. 2x12) would help distribute the weight. Reico-Titan replacements would be my recommendation, but be aware that the gearing ( rate of raising/lowering) may be different than your existing Happy jacks. It would mean you’d have to toggle between the two different brands to play catch up to keep the camper level.
