Clayto1332
Sep 17, 2018Explorer
Help with a fixer upper!
Hello guys and gals. I am new to the forum because I am new to RV ownership. If I am posting in wrong place, please move to correct place.
So I acquired a Forest River Surveyor SV291 in a trade. Most importantly the flooring sags and I suspected rotten wood. I began removing it and saw it was foam panels laying atop metal beams with a waterproof barrier. The foam had just been destroyed my someone's weight or heavy items I suspect. I have plenty of 2x4 and 2x6 at my disposal. My question is can I take out these foam panels and put 2x down as the subfloor and maybe put hardwood over it? Or would it add too much weight? I am having problems with the slide too but I will make a new thread on it. Also what is that waterproof lining called? Can it be patched or should I replace all of it. It seems good in the front part of the camper. Attached are a few pictures. Thank you guys in advance
