Dandy_Dan's avatar
Dandy_Dan
Help With Hitch on New Truck
I need assistance from those that may have had the same problem. I have a 5er that used to be towed with a 2005 Dodge Quad Long bed. Recently I snagged a "used" 2014 Chevy 3500HD dually.(only 7000 miles and also long bed)) I need to get more clearance when hooked. I was backing into my parking space and not cranked off very far and something around the pin box bumped the top of the bed rail. This truck has the covered bed rails.
I was too ignorant to stop and look to see exactly what got into the tonneau cover rail as it just scuffed it. I have had my hitch rails from the Dodge reinstalled with new brand specific hardware. I installed the A frame and then the 5er hitch plate. The hitch is set in the highest hole. It is a Reese Pro Series 5th wheel hitch. I am open for suggestions on how to raise the hitch height of the 5th wheel plate. I have had suggestion to drop the pin box down to raise the height of the hitch plate and pin, then cut off the part of the angle. Thanks in advance for any suggestions.
  • If the hitch is adjusted all the way up then the only other easy thing you can do is lower the pin box assuming it is not already at it's lowest setting. That pin box is heavy and you should have at least one other strong helper if you do this yourself. If you look at the pin box you'll see the bolts that need to be removed.
    There are a number of pin box videos on Youtube one may help you:
    link
    this thread may help:
    link
    If that doesn't work then the fiver axles would need to be 'flipped' probably by a trailer shop unless you are very very handy. Welding is probably needed to do this.
  • Dandy Dan wrote:
    .... drop the pin box down to raise the height of the hitch plate and pin, then cut off the part of the angle...
    Hey Dan, since you already have the hitch as high as it will go, dropping the pin box seems like your only option, at least using your present hardware. What do you mean, "...cut off part of the angle." :h
