penguin149's avatar
penguin149
Hitch weight on Hybrid trailers?
I've been looking for a 20ft +/- TT to tow with my 2012 Nissan Frontier. 4.0L V6. The max tongue weight is 630#, max trailer weight is 6300# and payload is 1485#. Lately, I've been checking out hybrids and the hitch weight on 3500# trailers is around 500#! Does that sound right? That seems high compared to the non-hybrids I have seen. 500# of tongue weight along with the family pushes me over 1000# in the truck plus whatever I may put in the bed.
How concerned should I be to get so close to the max tongue weight, and in turn, max payload?
Thanks for any input or advice.
  • Note a WDH DOES NOT CHANGE THE TONGUE WEIGHT REQUIREMENT. It just helps keep TV front end from pointing to sky. A good WDH includes sway control, like Equalizer or Reese Dual Cam.
    Tongue weight should be between 13% to 15% of the FULLY LOADED TT weight.
    You should be OK as far as payload goes. Just don't load the truck bed up like Jed Clampett did.
    You'll be a lot closer on tongue weight, so a weight distributing hitch makes good sense.
  • That's around 14% which is normal. 12 to 15% is the suggested range for best balance.
  • My hybrid's tongue weight is 600# weighed ready for camping. This on an RV that has a GVWR of 3500#.
