- TxGearheadExplorer IIFairly common sight in oilfield country, carrying pipe and tubing.
- NRALIFRExplorerThis truck has the base, wimpy, non-trailer tow mirrors.
Looks like they might fold in, but don’t extend.
The brackets are more than 12” wider than the truck. I’d stake your life on it :W
:):) - Kayteg1Explorer IIThis is SRW F350, so I have no experience, but my dually had side mirrors at above 9 ft wide before extending.
- JRscoobyExplorer II
Kayteg1 wrote:
Not surprising any subject brings lot of speculation.
"Wide load" signs are not legal in lot of states, so generally the "oversize load" should apply here.
When the racks sticks about 1 foot past bumper, making it about 9 ft wide, it is about the width of side mirrors, so maybe the law of small brackets sticking past 102" legal width apply?
That load sure calls for center support, flags and holding chains, but seeing the truck on center lane, doesn't look like driver is concern.
Brackets stick out about a foot on one side makes it 9 feet wide? Side mirrors in normal position are less than 102. And if less than 102, the width is no reason for flags and signs. - Kayteg1Explorer IINot surprising any subject brings lot of speculation.
That load sure calls for center support, flags and holding chains, but seeing the truck on center lane, doesn't look like driver is concern. - JRscoobyExplorer II
Geo*Boy wrote:
I worked for a rebar fabricator and hauled quite a few loads of rebar. I know how to secure various sizes of rebar and I would have been fired, and rightfully so, if I hauled rebar like that. It’s flat out dangerous.
Yes, this should not be the way to haul rebar. And when my skateboard had a headboard mounted to the front of it. Most pros pulling a flatbed have their protection mounted tractor frame behind cab instead. This means in a sudden stop, if the load shifts it has at least 5 feet to be moving faster than the driver when it hits the rack.
I'm not saying this is a good/safe way to haul. What I'm saying is if you are going to be upset about this unusual method, you maybe should take issue with the tons of bar and pipe that moves out to small jobs on roof racks and such. Better that load does not get loose, but if it does the launch from low like that is much less likely to do real harm. - stevenalNomad IIEven if he's within width requirements, the driver cannot see where the extensions are. Note that he is not within his lane.
- Geo_BoyExplorer II
JRscooby wrote:
Geo*Boy wrote:
Are you kidding, that truck gets into an accident and those rebar become flying projectiles. Yeah, your right whats the real danger?:S
While this statement is true, IMHO, it is made by somebody that does not pay a lot of attention to the way things are normally done. Sure, pickup hits something, that rebar keeps moving. But it will be hitting the ground probably before the back is clear of front rack. Most likely any damage done will be to tires or feet/ankles. Not Good.
Now let's look at the same impact, same bundle of bar, loaded in the normal manner, a rack over bed and cab. The bar is launched at at the same speed, but starting at over 6 feet in the air. With the same drop rate it can skip off the roof of the car the truck hit, off the deck lid of the car stopped in front, and into that car's passenger compartment. But it must go much farther before it hits anybody in the ankles. I think even worse.NRALIFR wrote:
Looks like it needs a “Wide Load” sign to me.
Not unless eight and half feet.
I worked for a rebar fabricator and hauled quite a few loads of rebar. I know how to secure various sizes of rebar and I would have been fired, and rightfully so, if I hauled rebar like that. It’s flat out dangerous. - JRscoobyExplorer II
NRALIFR wrote:
It’s at least that.
The trucks bumper is 6’ wide, and my calibrated eyeballs say that’s more than 15” to the end of the extensions. Looks more like 18”, but just for reference license plates are all 12” wide. Compare that to what’s sticking out past the ends of the bumper.
Maybe he knows the width limit, and it’s 1/4” under. :W
Well no state would issue a permit for that load. And my experience has taught me that few LEOs will notice somebody is a little over without a sign. Sign would cause more problems than solves.
Going off in weeds for a little humor. A company in KC, who's main job is cranes. All their tractors have blanket permits, so a load up to 10 feet wide does not require special calls to state. Some of the booms, they had issues with the cribbing failing because needed to stick out past the side of trailer so far. Management had the shop build some trailers 10 foot wide, to reduce this problem. As long as there is a load over 8.5 feet wide on the trailer, works great. But normally when the big cranes go out, the trucks make a few trips with boom sections. A MT trailer on the ground is not a load. But 2 of them stacked on a 102 can cross the scales. - jimh406Explorer IIII agree it’s probably too wide. But, hey, I don’t think they are following any normal standards, so it’s ok, right? ;)
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
