Joe_Sales's avatar
Joe_Sales
Holding tank capacity
I have a 2000 citation truck camper (General Coach) and I can not find any specs for the capacity of my holding tanks. Fresh Water, Grey Water, and Black Water.
For that matter I do not have any specs for anything with this camper.
Could anyone help me?
  • Wow, resource always forget about, Wayback Machine...
    https://web-beta.archive.org/
  • Barring anyone actually owning same........nothing available
    SO get 3 or 5 gal bucket
    Use it to FILL each tank......# buckets X gal used.
    Then drain into bucket to check numbers
    Start with Fresh water tank 1st :B
  • If you can measure the dimensions of the tank, you could figure it out. Otherwise, can you be more specific about your model?
  • For a camper that old...I seriously doubt if you'll find any information on it. For the tank capacities, I would just start filling each tank (one at a time) with fresh water using a gallon bucket...or maybe a five gallon if you can handle the weight lifting it up.
    Keep track until full.
    Ron
  • if you have access to the tanks measure them
    WxLxH= /231 will give you the gallons
