ford_truck_guy
May 09, 2020Nomad
Hooked it up
Finally hooked up the the new Ford to my RV... I am finished with all my add-ons as i just added the Roll-n-lock and Firestone Ride rite bags..
Me Again wrote:rhagfo wrote:
Well as Ron pointed out it is an$1,400 option on Ram I don’t think Ford would just give it away.
Did you miss the fact that I was talking about the type of air bags Ford owners all seem to have to add to handle the sag when pin weight is added?
Me Again wrote:rhagfo wrote:Cummins12V98 wrote:Me Again wrote:ford truck guy wrote:
blofgren -
No, didn't have the time today...
Cummins12V98-
Ron, I have then at 45 and will tweet them when I pull it..
bgum -
Thank You
Ron3rd -
Thanks, Can't wait to take it for a road trip..
Ford should make air bags a factory options, as just about everyone installs them. I do not know about GM's but the newer RAM do not need them.
Option: Firestone airbags check here ( ) $200
or
Option: Delete Firestone airbags check here ( ) -$200
A lot more to it than that. My option was around $1,400 and WELL worth it for automatically maintaining ride height even with 6k pin.
Ron, that was my thought also $200 wouldn’t even cover retail cost of the bags. That is the one option I wish our 2016 had, still a better ride than the 2001 2500.
Price goes down when one is buying hundreds of thousands of them.
blofgren -
Cummins12V98-
bgum -
Thank You
Ron3rd -
or
blofgren -
Cummins12V98-
bgum -
Thank You
Ron3rd -
or
Cummins12V98 wrote:ford truck guy wrote:
blofgren -
Cummins12V98-
bgum -
Thank You
Ron3rd -
I will have to see if I can "TWEET" my OE air bags. ;)
Chris -
My weights on the Redwood loaded for camping:
Pin- 3460#
Axles - 12,860#
Total - 16,320#
My truck has a 12,400 GVW and 30,000 GCVWR
payload capacity per sticker- 4561#
you are correct with the RAWR of7230 ( weak link) along with tires at 7500
no plans on a washer-dryer, and my weights include the Onan up front
So what was the TV rear axle weight?
My rear axle ready to tow was 3760. Demco Picture Frame, B&W manual slider and boxes full of stuff. Chris
ford truck guy wrote:Lantley wrote:
Looking good. How's your bed rail clearance? It looks a little tight in the photo. But the angle of the photo maybe misleading.
I have 7-1/2" clearance as of right now..I am on the middle setting on the B&W so I can raise it 1 more setting... Want to get up to. big, level parking lot to get some measurements and see how it is sitting...
Chris -
Pin- 3460#
Axles - 12,860#
Total - 16,320#
