S_Davis's avatar
S_Davis
Host slide width?
Does anyone know what the width of the dinette slide is in a host Ranier? Trying to figure out if theater seating will fit instead of the dinette.
  • The forced air furnace is located under the dinette. Not sure of the width but looks too narrow for the theater seating host supplies in the Cascade. A call to Host could confirm the width and whether you can delete the heater and install theater seating or order without furniture there. Just be aware the entry door is narrow and you would need something that would fit through later.
  • Ok thanks, I plan on removing the furnace and going a different route with the heating. Do you know if the furnace the only thing under the dinette?
    On the mammoth part of the blank tank is under there as well but that wouldn't be the case on the Rainer. Looking at the photos on the Host website it looks like there is interior storage. On the exterior there appears to be another compartment next to the heater. Not sure what that is. Definitely worth a call to Randall at Host. No point in paying for a heater just to remove it if they can build one without and not have the cutout in the side of the camper.
    edit. Wrong side. Looks like just the heater on the dinette side.
  • I need to call them, I will not need the water heater either. I am just trying to figure out if theater seating will fit.
  • Why not just buy a tent for $100 doesn,t sound like you need to pay for all that extra stuff.
