RollandBC's avatar
RollandBC
Hotwater Heater
Hello, ok with my furnace fixed it's onto the Hotwater Heater.
It's the manually lit pilot light.
This season I fired it up and after lighting the pilot and putting it in the ON postion, instead of a nice smooth burning BLUE flame its a wobbly weak orange light causing smoke and black soot at the exhaust.
Any suggestions
  • Yes this 1 took about 15 minutes.
    Works good now!
    Thanks everyone for your advice :)
  • Typical RV water heater size tanks are 6 gallon, 10 gallon, and bigger for larger coaches. My standing pilot 6 gallon water heater takes about 10 minutes to fully heat the water.
  • I believe I found the answer >>
    "While they can vary in size, the most common size of water heater is 40 gallons, which is what we'll be using here when talking about how fast they work. The bigger the heater, the longer they take to heat up the water. The average gas heater takes between 30 and 40 minutes to fully heat up the water in its tank"
  • Ok I managed to find time and got the tube out, a quick look and there was just 1 little wisper of dust.
    Cleaned it out and used a soft brush on the fuel tip.
    Fired up with a nice steady blue flame.
    How long does it take for the water to warm?
  • Had that on my heater. After cleaning it still happened. Finally found a wisp of a spider web in the tube.
  • Bug nest in the burner tube, most likely. Clean it out and you should be good to go. Resist the urge to poke anything into the gas metering jet. It is easily damaged.
  • Ok I'll pull the manual for it and run through a cleaning in the morning
  • The burner tube sounds like it is plugged. Bugs or dirt maybe.
