Sort By
- GrooverExplorer II
Jvandererlip wrote:
I found this interesting thread in another forum. It's about the 2017 eco diesel RAM air suspension. A guy tested his to see when the air suspension would start throwing error messages.
Couldn't get off road 2 at 600 lbs over and it wasn't until 850 lbs over before it quit leveling.
https://www.ram1500diesel.com/forum/ram-1500-diesel-suspension-chassis/2481-air-suspension-limits.html#/topics/2481?page=3
Thanks, I have been wondering how they handle gross overloads. - GrooverExplorer II
Jvandererlip wrote:
I hit the CAT scales and my estimate of being slightly over the GVWR was correct. I'm 180 lbs over but below the axle weights by a good margin. That's with a full tank of gas. In the bed of the truck is a generator, two folding bikes and spare fuel. Rear axle weight is 3880 (4100 lb limit) Front is 3400 (3900 limit) brings me to 7280(7100 limit) Trailer axle is 5560.
I'm fine with those weights. That's even lighter than I had hoped on the rear axle so as far as I'm concerned it's a perfect setup.
Sounds good to me. I have always wondered why GVWR would be less than the combined axle limits and assumed that it must be a cooling issue with the transmission or brakes. Or maybe it is just to give you some flexibility in where you put the weight. Whatever, you are only about 1.5% over and that is with a full tank of gas. I feel sure that there are a lot of vehicles on the road more overloaded than that with drivers that are blissfully unaware of what they are doing. With the care that you have taken so far I am certain that you will make adjustments in your driving to stay safe. - JvandererlipExplorerI hit the CAT scales and my estimate of being slightly over the GVWR was correct. I'm 180 lbs over but below the axle weights by a good margin. That's with a full tank of gas. In the bed of the truck is a generator, two folding bikes and spare fuel. Rear axle weight is 3880 (4100 lb limit) Front is 3400 (3900 limit) brings me to 7280(7100 limit) Trailer axle is 5560.
I'm fine with those weights. That's even lighter than I had hoped on the rear axle so as far as I'm concerned it's a perfect setup. - WalabyExplorer IIIm betting if you bide your time a bit longer, that dealer with the 2017 will call.... maybe.
I agree they are testing as you describe, but those weights (150 lb occupants and hitch etc) come of the test vehicle's payload. As your copy/paste states. Payload and GAWR must account for all the test weights. So it's not counting twice. I counted it off the payload, and the description above also counted it off payload. So, either way it comes off payload, so you have to account for it.
I don't think anyone is upset.
Stick to your guns on that 2017.. they will come around.
Mike
Mike - BeerBrewerExplorer
Walaby wrote:
Beer Brewer
It's not hard to understand. J2807 is a testing standard for determining tow vehicle GCWR and Trailer Weight rating. It is NOT a methodology for determining payload!. It tests to max payload capacity, and uses the items you describe (and others) to determine tow rating, but that does NOT change the payload of a vehicle.
You cannot say because the J2807 standard tests with 300 lbs of passenger and 100 lbs of tow equipment, that the payload of a vehicle magically is increased by 400 lbs.
In fact, the word payload doesn't even appear anywhere in the doc you referenced.
Mike
Mike...All I'm saying is when the SAE runs a pick-up through their tests, they do so with a 150 lb driver, 150 passenger and 100 lbs of misc weight in the truck. So there is no need to add these weights again. Ram has the following statement on all of their Trailer Towing charts to inform the readers how the trucks were tested, so if they are carrying more driver and passenger weight or cargo, then stated that they need to factor the additional weight in.
7. Trailer Weight Rating and Tow Vehicle Trailering Weight are calculated as specified in SAE J2807.
Passenger Weight = 300 lb
Options Weight = 100 lb
Tongue weight: 10 percent of the gross trailer weight for Conventional Hitch, 15 percent of the gross trailer weight for 5th Wheel or Gooseneck hitch.
Trailering Equipment Weight: 75 lb for Conventional Hitch, 70 lb for Gooseneck and 250 lb for 5th Wheel.
Payload and GAWR should never be exceeded and must account for all of the above weights, including the appropriate trailering equipment and tongue weight.
Box Off Body Completion Weight = 80 lb per foot from end of cab to end of frame.
I didn't mean to get into a long debate or get anyone upset over this. Lastly I also agree with you that it probably isn't smart getting so close to a trucks capacity that you need to worry about a couple hundred pounds. For instance I was seriously considering purchasing a new 2019 RAM 1500 to pull a 8000 lb trailer. It's a real nice truck but I when started running the numbers I could see myself betting getting real close to max payload of the truck even though I was below what the spec says it can tow. It was just too close for comfort, so I've decided to bite the bullet and purchase a 2018 RAM 2500. My only decision left was between a gas or diesel engine...I am leaning towards the diesel. - RoyJExplorer
Jvandererlip wrote:
Fortunately the bikes are folding bikes and can fit in the aft cargo bay further reducing tongue weight. I'll load it with the bikes in the bed initially and get weighed. The suspension will error out if I overload too much. I think I'll be good. I'm pretty sure I can avoid buying a 2500 since my Infiniti towed this beautifully.
If you're concerned about staying under limits, every modification help.
Put as much gear in the trailer as you can, only passengers in the truck. Then remove the tailgate and put the spare in the trailer - those 2 items alone can be 150 lbs, and more importantly, 150+ lbs off the rear axle.
Can even go as far as relocating the propane tanks and batteries to the middle of the trailer. But be careful, as you reduce tongue, you'll want a better anti-sway system. - WalabyExplorer IIBeer Brewer
Mike - BeerBrewerExplorerDeleted
- Perrysburg_DodgExplorer
ScottG wrote:
I believe the 2018 RAM is the same so you may want to hear from those folks as well.
The 2019 is a 5th Gen truck and the 4th Gen 2018 that is still being sold but as a 2019 Ram 1500 Classic. You can also buy a 2018 Ram 1500 with the Ecodiesel option.
Don - BeerBrewerExplorerBelow is a link to the actual spec. It goes into great detail on what is inclued and what is not. See Section 3.2 TOW-VEHICLE TRAILERING WEIGHT (TVTW)
http://fifthwheelst.com/documents/tow-test-standards-2016-02.pdf
About Travel Trailer Group
44,029 PostsLatest Activity: Apr 26, 2025
