โFeb-04-2014 10:02 AM
โFeb-09-2014 05:24 PM
โFeb-09-2014 09:35 AM
myredracer wrote:It certainly does!
That does makes sense, thanks!
โFeb-09-2014 09:27 AM
abaerga wrote:It's always good idea to remove a failing material rather than covering it up with new material. In the case of your skylight, you will get a better and more consistent bond by removing as much of the original caulk as possible.
I have a skylight in my shower that leaks. Should I remove the old caulk first?
โFeb-09-2014 05:01 AM
โFeb-05-2014 05:28 PM
AirForceAngler wrote:myredracer wrote:
How much is a pressure test really going to help to find water leaks? There are lots of places where air can leak that aren't a problem (requiring repair) like the weep holes at the bottom of windows; around holes through the floor around pipes, ducts and wiring; around the fridge opening; ceiling vents; slideouts; etc. Just curious, maybe I'm missing something...
Water can ingress even in through hairline cracks in a wall or roof membrane that you can't even see sometimes. That's been one known cause of water ingress in buildings and mold and became more commonly known as a result of the "leaky condo crisis" of the 80s.
I would think a close visual inspection would be better along with regular maintenance. I think an RV cover would help somewhat as a preventative measure.
The fact that water CAN ingress through hairline cracks and other place you can't see IS the reason for a pressure test. You pressurized the camper then spray on the mixture of water and dish soap and look for the bubbles. Of course you're not going to worry about the weep holes and other natural leaks, but you want to take care of the leaks that aren't supposed to be there.
You can inspect all you want visually, but even what looks like a good seal can leak. My first camper was a good example of that. Bought it new and within 3 years, there were at least 4 rotten places in the floor with no visible leakage signs on the ceiling or walls. My guess is it was leaking through the door/camper seal and window seals that all looked fine to the eye.
โFeb-05-2014 05:17 PM
โFeb-05-2014 02:13 PM
โFeb-05-2014 01:44 PM
mlts22 wrote:I dunno, I think my Eternabond job looks lot better than some of the caulk applications from the factory. They really need to calibrate those air-assisted caulking guns, lol.
The only downside of Eternabond is that a potential buyer might consider it a "hackjob". This is ironic because Eternabond is a lot better than caulk, but appearances sell.
Were I keeping my TT for the long haul, I'd be paying a few people a couple hundred each, and having a day where all the fixtures (skylights, vents) get replaced/upgraded, the roof primed, the tape laid down and pressed flat with a roller, then the tape's edges caulked. However, since I plan to sell my TT either this year or next, I just make sure all the joints are sealed tightly every 90 days.
โFeb-05-2014 12:41 PM
โFeb-05-2014 12:20 PM
โFeb-05-2014 11:45 AM
โFeb-05-2014 11:37 AM
AirForceAngler wrote:I was referring to Eternabond tape as passing the 100% success test. I used two different types on my roof, Eternabond Roof Seal (vinyl backing) on all cross seams, around vent through holes, and around vents. I used Eternabond Webseal over the roof's aluminum edge trim. Webseal needs to be coated to prevent UV degradation but I painted the roof with one of those roof products so it was coated in the process.Jerry9n wrote:
Westend X2 on the Eternabond. I went back a year later and retested and found a few more leaks where the caulk had cracked, but nothing on the Eternabond.
If you are worried about pressure (my furnace blower was two speed), crack the roof hatch a bit. The furnace blower is not made for a high static pressure. You probably have to be a little more careful, though, with a leaf blower.
Are you referring to the Eternabond tape or what product?
I have a serious furnace blower! It came from an industrial unit so I'll be careful! It's a good bit larger than the one pictured here earlier.
โFeb-05-2014 10:14 AM
โFeb-05-2014 10:04 AM
