Aug-17-2018 06:31 PM
Sep-02-2018 09:20 AM
lewisr wrote:Ralph Cramden wrote:Lantley wrote:Ralph Cramden wrote:Lantley wrote:
@ Ralph Cramden
Once upon a time I took your approach. But now I realize the electric awnings are just too flimsy to survive a strong wind.
I put my stuff under the fiver overhang for the night and just press that button and not worry about any overnight gust or what the weather is going to do.
I awake and push that button again and all is well.
I no longer feel the need to protect my table/stuff with the awning overnight.
It's not worth the risk.
Mother Nature can easily destroy our flimsy awnings despite our best attempts to strap them down with various gadgets
I feel little risk if any, since my various gadgets have proven themselves on more than one occasion, including the one when the ranger station 1/4 mile away recorded 70 mph gusts and 45 mph sustained winds.
Your awning/technique must be better than mine. I would not suggest leaving out an awning in 70 MPH winds, that's just me.
Your table must be pretty sturdy as well as the 70 MPH winds did not affect it either.
Yes I consider 70 MPH winds a risk, I will push the button.
The 70 mph gusts were in a popup storm while away at the lake, took out a few popup canopys and knocked down some tents.
On another forum a gent makes and sells aluminum brackets for pole attachment on Dometic awnings, basically a kit that comes with a detailed plan for the poles, the brackets and mounting hardware. Another member had been making and selling the poles. They are self storing so you have the option of using them OEM style or not, and you need not store the poles elsewhere, and they take less than 5 minutes to deploy if you want to use them. Want to run the awning in? Pull two ratchet straps and two pins....have at it. 30 seconds or less.
Those guys sold hundreds if not thousands over the last few years, actually could not keep up with orders, so I guess they dont work and are a bad idea. Especially since I dont remember ever seeing one post where someone lost an awning when using them other than when the user screwed up, like using unsecure ground anchors. But then again here at RV.net, having absolutly no experience with a modification qualifies one as having a high level of expertise with something they have not had and know absolutely nothing about, as per usual.
Run your awning in and out half a dozen times a day if you wish, have at it.
As far as power or manual.....good luck getting a manual now days as a lot of manufacturers will not install a manual one even by special order. Rockwood had agreed to install a manual when we did a factory order in 2015....with a caveat that they would not cover the lower bracket attachment points under warranty because backing was installed in the mass produced laminated wall panels for the power awning, and there was no way to alter or add more to align with the manual attachment points.
I bought the brackets you speak of and made my own poles with black pvc. I use rachet straps and “The Claw” hold down stakes. Very sturdy setup. I leave mine out all day and night.
Sep-02-2018 08:25 AM
@ Ralph Cramden
Sep-01-2018 06:03 AM
Sep-01-2018 04:57 AM
spoon059 wrote:
I don't leave it out when we are gone for the day. Unless I expect strong winds at night, we have left it out over night. It keeps the front of the camper dry in rain or dew and keeps the sun at bay on that side so we can sleep longer and cooler in the summer.
We always make sure to keep the arms clear of obstruction at night so that I can easily retract it if we hear wind or banging.
Aug-23-2018 04:39 PM
Aug-23-2018 01:18 AM
@ Ralph Cramden
Aug-22-2018 04:55 PM
Farm Camp wrote:
I've seen a few fellow campers lose their awnings too I have to admit. .
Once I found myself out at 4AM quickly unhooking the straps and pulling it in when a really nasty thunderstorm rolled in. The rest fo the time it's just been there doing it's job. I might loose it someday. It might wear out too.
Guess I'm lucky so far, but, I've noticed while out camping that many or maybe most of my neighbors seem to use a similar strategy of using their awnings for their intended purpose, tying them down if they feel the need, and pulling them in if wind gets really bad...
Aug-22-2018 04:46 PM
@ Ralph Cramden
Aug-22-2018 03:54 PM
Aug-22-2018 12:15 PM
Aug-22-2018 09:20 AM
Lantley wrote:
@ Ralph Cramden
Aug-22-2018 04:26 AM
Aug-22-2018 03:54 AM
Aug-22-2018 03:29 AM
Lantley wrote:
Electric awnings are all about push button convenience.
It's hard to teach an old dog a new trick, but there is really nothing to debate. Bring it in. Why take a chance? Extend or retract requires little effort.
Just push that button at bedtime and push it again in the morning.
