Ezbagr's avatar
Ezbagr
How often do you rotate tires?
Just read the thread where a guy was complaining about terrible tire life with general tires. I have a 1 ton dually 2 wheel drive 2007 Dodge Ram and I get 80,000-85,000 miles out of the General tires. I think the key is rotating the fronts to the back every 10,000-12,000 miles. I will rotate the fronts to the right rear and 10,000-12,000 miles later put the fronts on the left rear.
Another thing that I do is I only run 55-60 PSI in the rears even with towing a 13,000 pound fifth wheel. I do run 70 PSI in the front.
