jerem0621's avatar
jerem0621
May 24, 2016
How to back up trailer- Aerial View
Found this on YouTube- Thought it may be handy to visualize how the trailers are moving while making maneuvers and backing.
This is an arial view of a tractor trailer turning and backing. The first 6 minutes are so are with the tandem axles in their most forward position... While still further back than most TT and Fivers it is closest to demonstrating how our towable RV's move while backing and maneuvering.
Note: The 90 degree turn is displayed and you can see the trailer tires scrubbing sideways... This may help people see how effective it is to get to 90 degrees with a truck and fiver.
Video Link
The music is terrible (like elevator music) so you may want to hit mute.
Thanks!
Jeremiah
  • WTP-GC wrote:
    transamz9 wrote:
    There's a bid difference between a 53' van and a 40' 5th wheel. I have never had a time I needed 90* to put my 5th wheel anywhere and that is including spots that are 90* to the drive.The 280" wheel base on the tractor in the video also makes a difference in the need of 90*.
    And then there's the one early comment that's off-topic and totally unnecessary.
    Good video!
    How is it off topic? I drive semis too and believe me when I say they the to as as much different as they are alike so not unnecessary.
  • Anonymous's avatar
    Anonymous
    Thanks for sharing. This definitely would be helpful to those who are new to towing. Often times people have problems visualizing the basics like how the trailers reacts to trucks, setting up for backing, turning radius for the trailer, etc. Definitely an interesting view. One of the best uses of a drone that I've seen on YouTube.
  • rj, aren't you referring to the standard sight side back.
    The one that i never mastered was the blind side back where you could not keep an eye on the left trailer wheel. :h
  • My Dad was a long haul truck driver for over 30 years and taught me how to backup a trailer. His #1 tip is to always keep your eye on your left trailer tire - if you have to pull up to get a better angle, do it. That tip has served me well.
  • Hi Jeremiah; Thanks for the video. I struggle with backing my 5th wheel. Always ask the campground to give me a pull through. This is the season that i am going to master the backing. My new storage space demands it. The old storage space was a pull through. Sounds like cones and the city park parking lot is the place to get this done. Best source of information is the video prepared by other rv owners as well as the trucker video. Jim2007
  • Video reminded me of a parking job I had to do
    Went to visit a friend in Seguim WA.
    Had planned on staying at nearby CG.
    He convinced me......'Plenty of room at our place-----so and so was here last year'
    SO we went to his place
    Small roadway.........90* driveway that was 8 1/2' wide across a deep drainage ditch with decorative fencing on both sides :S
    Then I ask WHERE am I suppose to park it.
    Right here in driveway :H
    Now I am no novice when to comes to backing in......but there was just not enough room to maneuver backend of 5vr and front end of truck thru the driveway opening.
    Ended up pulling in ........driving out across front yard and then backing/jackknifing 5vr onto driveway. Had to dump sand across driveway so tires could slide easier across his brickwork
    (CG was FULL....no other options in area!!)
    That is the tightest/most jackknifed I ever had the 5th wheel----probably closer to 95/98* when finally parked. Roadside of 5vr was right next to back of cab and blocking rear quad door.
    That goodness for 4-way articulating hitch head.
    The visit with old friends was worth it!!!
    Good video!
  • I remember watching an old gentleman crank it over to 90 degrees to get his fiver into a tight spot. I was very impressed. Almost wanted one after that!
  • That is a really good video to show how the trailer moves in response to tow vehicle movement. Thanks for sharing!
    Video Link
    Thanks!
    Jeremiah
