T3rry1
Jan 20, 2015Explorer
i would assume if it's anything like mine it uses a bit of square tubing as conduit for the wires on the clearance lights, so you may be best to take off a top corner light, and the light and fish down from the corner and then to the center from the corner, that way you don't have to try to get around the corner.
or if you can find a loose wire you can disconnect it from the light, tie a string to it, pull it back through and out bottom, then tie your camera wire and the original wire and pull it back.
it's very possible, just depends on how much work you want to put in to it.
(mine is dutchmen so it may be different)
44,056 PostsLatest Activity: May 04, 2014
