This is not so much on mounting batteries on the trailer tongue but offering some pre-planning thoughts on getting setup with your smaller trailer. My battery bank is mounted across the top of the trailer tongue shown here... I am very prone to battery theif...
Having been camping off-road alot since late 2008 with a smaller trailer charging of the batteries is a big deal. IMO a small generator is a MUST HAVE item if you are going to be using your trailer for more than flashlights and candles.. Our present battery bank produces 255AHs of capacity...
The SOLAR of course only works when in high SUN and if the batteries are at zero or less than 50% charge state you have charging rules to follow to get them back up to their required 90% charge state before you start using them again. If you don't follow these charging rules then you will be replacing your batteries very early. Small solar panel installs will not produce enough DC current to maintain your batteries properly especially if you are draining them down to their 50% charge each day/night battery run.
The same goes with expecting the trickle charge coming from the truck alternator when driving between off road camp camping spots every couple of days. You will find yourself in deep trouble IMO expecting this to work for you.
We found out real quick just having 6 AMPS or so of re-charge DC Current available for short periods of time was not enough DC current to keep our batteries properly charged with our style of camping off road.
I have seen many times up to 20-22 AMPS DC current being drawn from the battery bank between the hours of 4PM to 11PM with our style of camping off road. This is alot more than just flashlights and candles...
Having the small 2KW portable generator around to use is most definitely a must have item for to use... Connecting the trailer on-board CONVERTER/CHARGER system to the 2KW generator will bring our battery bank up to its 90% charge state each morning when allowed in a three hour generator run time.
Public Camping on the East side of the US has more generator run time restrictions then camping on the West side of the US where there are more public off-road dispersed camping sites available.
Solar panels for us would be just enough panels to provide enough DC current in the 5-6 hours of expected high sun to top off our battery bank back up its 90% charge state after we have run the generator for the first one hour period to get our battery bank past the initial high current charge state. Then the smaller solar panels can get us to the 90% charge state before the high sun goes away. Keep in mind that a typical 120WATT Solar Panel will only produce a 5-6 DC AMPS that can be used to re-charge your batteries. Most trailers have a parasitic battery drain of 1-2 AMPS DC that is there 24/7...
We had to consider all of this in our planning for using our OFF-ROAD POPUP camper setup...
If you will convert your high current trailer lights to LEDs and maybe only run your HDTV set-up for a couple of hours each evening you can get by pretty easy on using the battery setup. Once you start doing this the want for more batteries comes on fairly fast.
To keep from getting into trouble 50 miles back up a good ole creek side camp site doing what you want to when camping I suggest you make a few dry runs in your back yard "with no cheating" and see how well you make it... This will let you know pretty quick where your short-comings will be...
By the way I don't have WDH on my loaded 4200lb OFF-ROAD POPUP setup being pulled by my F150 truck but in my case the very low wind resistance with my trailer in its down travel mode probably has alot to do with being stable going down the roads. If I was pulling a higher trailer I would most likely want to install the WDH... We travel on the smaller two lanes road alot verses the Interstates and the wake from one of those hugh Georgia Pacific log trucks loaded to the maximum height with logs going 60-70MPH will swamp you out on a two lane roadway in a heart beat especially if you pulling a normal height trailer behind you... The last thing you may remember is the big smile on the truck drivers face... hehe
This is what we usually look like camping off-grid here along the Blue Ridge/Skyline Drive high country somewhere.
This is all based on my camping experiences - I'm sure others will have different thoughts...
Roy Ken
