wgriswold
Sep 20, 2021Explorer
How to remove the shower door
The shower in my 2018 25Y is a SEA NEO Angle A025.
My shower door is difficult to close and destroys the gasket on the bottom because it in not plumb and rubs against the sill at the bottom of the non-hinge side. I have directions on adjusting the door but they involve essentially taking the shower apart and rebuilding it and I am nervous about that.
I have put a small nylon washer under the lower pin by notching it and forcing it in. This raises the door enough to solve the problem, but the washer soon works it way out. Currently I have wrapped some brass wire around the pin and that works but I am afraid that the wire will wear against the surfaces and cause problems. I may try to use string as a less abrasive solution.
What I would really like to do is remove the door and install a brass washer on the pin. I can't figure out how to remove the door. The top door header has no obvious way to take it off and that is required to lift the door up. The directions for installation of the shower do not mention this part. It just appears in step 4.
Has anyone removed the door and if so how did you do it?
