Jan-26-2019 09:22 AM
Aug-14-2019 03:31 PM
Aug-14-2019 01:58 PM
Aug-14-2019 01:31 PM
trofeo16 wrote:
so I'm sure this topic has been completely exhausted but wanted to specifically ask about the a fiver with my 2018 Ram 2500 with the 6.4 Hemi. I currently tow a Travel Trailer (vibe 308bh). Dry weight of 7300 and loaded about 9k. I travel off long island once or twice a year to maryland at the farthest. Most of my camping is withing 40 miles. I am considering getting a Grand Design 311BH. Dry weight of 11,300 and a pin weight of 2000. I know i'm good with payload but what do you think about towing a rig that heavy with the hemi?
Aug-14-2019 10:44 AM
Feb-06-2019 11:03 AM
FishOnOne wrote:We haven't found this to be true with our '16 Ram 3500 SRW 6.7. With 40-45 psi in our rear tires, truck totally empty (approx. 3k on the rear axle), there's still a slight loss of road/tire contact on the very outer edges of the rear tires. Increasing rear tire pressure to 65-70 psi with the truck totally empty, we lose even more road/tire contact on the outer edges of the tire. Hard to get even wear if a portion of the tire is not contacting the road.
Running these trucks with ~40psi compared to ~65psi increases tire wear rate.
Feb-04-2019 07:59 AM
Feb-04-2019 05:15 AM
Feb-04-2019 04:55 AM
Grit dog wrote:
^ Im sure he means 40psi in the rear tires. And that does not increase tire wear. 40psi in front of a diesel on stock ish size tires is very squishy. Even the most uninformed would notice an issue with that.
60F/40R give or take based on load, road conditions, seasons, tire size and type is the RIGHT ballpark for pressure on unladen HD pickups. This is only debateable if one is obtuse, ignorant or....yup just those 2 reasons.
Feb-04-2019 03:05 AM
ib516 wrote:I'm running 65 psi in the rear tires while empty. Took my wife out to dinner the other night in it and to my surprise, she stated that she thought that the 2500 ride was much harsher. I didn't say a word... :@2012Coleman wrote:
I just upgraded (last week) from a 2017 Ram 2500 6.4 Hemi to a 2018 Ram 3500 CTD SRW Aisin trans. There is no difference in the ride while not towing - daily driver for commuting to work and back.
Exactly opposite to my experience in comparing the empty ride of a 2014 Ram 2500 Hemi to a 2014 Ram 3500 SRW CTD. Identical trucks other than the 2500/3500 and the engine. The 3500 empty was punishing compared to the 2500 with the coils. Small choppy bumps were where the difference was most evident.
Feb-03-2019 09:39 AM
Feb-03-2019 08:03 AM
Feb-03-2019 05:08 AM
Me Again wrote:Walaby wrote:
Sold my 2014 2500 CTD, bought a brand new 2017 3500 CTD.
It does ride harsher to me (coil spring vs leaf spring), but when I reduced the air pressure in the rear tires from 75 to 50, it softens it up quite a bit. Air up for towing, air down for driving.
Mike
I run my 2015 at around 42-44 lbs empty.
LT275/70R18 and LT285/60R20
PSI RATING
35 2070
40 2270
45 2470
50 2680
55 2840
60 3020
65 3195
70 3360
75 3530
80 3640
Even at 40 lbs inflation you have the capacity of about 1000 lbs more than the empty rear axle.
Feb-02-2019 05:08 PM
Jan-31-2019 07:05 AM
Jan-31-2019 05:03 AM
Mike
