samhain7's avatar
samhain7
Hub temperature
I bought a laser temperature gauge for the trailer. Just took a 4 hour drive to windsor.
All 4 hubs on the trailer were around 110 degrees +/- 5 degrees
What is an acceptable temperature?
  • Yup....got it right before all the news came out about exploding tires and roll-overs.
  • GMandJM wrote:
    My TPMS factory default to alarm is 157f, FWIW.
    The Exploder had a sticky caliper a few weeks back and the temp was up to 136f when we realized there was a problem. (The smell was very evident).
    So with that in mind, I can't give you the perfect safe temp, but I woud presume for my SUV it's somewhere UNDER 136f.
    When it comes to hub temp you're also looking for some consistency. If three are 110f (+/- a few) and the last one is 130f for no apparent reason, you'll want to look into it.
    Exploder :p
  • FYI
    I found this out from work and I was not aware of this.
    The Infra Red guns will not give you an accurate reading on a shiny surface! Put a piece of black tape on the surface then get a reading.
    We have a high pressure vessel with temperature and this was discussed by our pressure and temp engineers at a safety meeting we had.
    Hope this info may help someone I would have never known.
  • I have an IR gun but usually touch each tire and hub by hand at each stop.
    They are usually warmer on the sunny side but never too hot to touch.
  • Just point and shoot center of the hub for me. Do it in approximately the same place for each wheel. I also do the tires.
    Nothing fancy.
  • How do you guys read hub temperature? Do I need to pop the caps off before I start a trip?
    TPMS tire air temp alarm at that 157*F
    Hub/bearing temps can run much higher w/o issues.
    Hi Temp wheel bearing grease (red grease)is rated for up to 300*F continuous use.
  • My TPMS factory default to alarm is 157f, FWIW.
  • You are looking for a hub temp that is out of whack of others.
    3 of them at 125* and 1 at 140*........that one needs watching
    I have 90*F to 160*F as long as both on same side are close to each other in temps (sunny side to shady side 10*F to 15*F difference)
    Also ambient air temps........68*F outside vs 115*F outside.
    Look for trends and for 1 that is hotter
