For those who have both Hughes as well as Surge P .
Can the hughes also be used with an additional surge protector ??????
From what i can find , I think it depends on which model surge .
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28543300/srt/pa/pging/1/page/1.cfmI know its not the best but I have a portable surge model 34830 (30amp) Approx $250.00
specs:
Shuts Off Power in Event of:
•Open Neutral
•Open Ground
•Low (<102V) and High (>132V) Voltage
•Thermal Line/Load Overtemperature
Indicates:
•Voltage and Amp Draw (RMS)
•Surge Failure (light indicates when surge protection has expired)
•Reverse Polarity (miswired pedestal, elevated ground voltage)
Features:
•2450 Joules surge protection
•6500 amps spike protection
•120 volts, 30 amps
•10/3 cord
I want to use it in conjunction with an older Hughes autoformer.
Im still a little confused in what order to use them . :h
I think , the order is .....
you park - Hughes - Surge - RV .
is the correct order ? see post "wA8yxm"
