Does anyone here run an ALDE heating system in the USA? As far as I can tell, only some Roadtrek Vans and T@B trailers have them. They are quite common in the EU and UK, however. I cannot believe these are not more common here in higher level coaches and 5ers. I'd pay the extra $3K for this.
I finally had some time to test the "damaged" (only the case was dented) ALDE boiler I got on fleabay. It works!. It is very quiet, just a low hum from the pump and the growl from the burner is practically nil, Sounds about like a stovetop burner on high. Once this thing is in a cabinet, I probably won't even know it's running. The exhaust is the same diameter as 1 7/8 Auto exhaust pipe, so I'm set there. I can fab it to the existing escution on the Attwood Blast Furnace and wake you up all night long noise maker. That Attwood is going on the junkpile.
I am testing with a Hayden Transmission cooler, since I cannot use Copper in the system, I am not able to use the low cost Slant Fin type baseboard heaters. I will be putting a coil of tubing under the bed for radiant heating.
Awesome unit! It will probably run from a regular wall thermostat, as I am sitting here typing, it is cycling on and off with an internal thermostat on the boiler, I presume.The boiler shuts off, but the pump stays running to keep the stored heat moving through the system. I really do want to get one of the ALDE controllers, however, as they give you different BTU levels and will also allow heating on AC Mains voltage instead of, or in addition to propane, as well if it's present.
Here are some pics of my test setup before I install it in the coach. It's going into my 2010 25' Nomad TT.
-CHR$
1996 Safari Sahara Edition 35' Diesel Pusher. Just getting the Solar stuff started.
