Dec-26-2017 11:10 PM
Jan-17-2018 08:20 AM
Jan-17-2018 05:27 AM
Jan-16-2018 07:59 PM
Jan-16-2018 05:19 PM
Jan-16-2018 02:29 PM
Phancy wrote:
I have a 04 Silverado with Linex spray bed liner with a rubber mat sense the truck and camper were new, absolutely no rust. The 1161 rarely comes off the truck and has been garaged when not in use which is not often. As far as insulation with this set up not sure because have always used it this way. When we winter travel I usually put the carpet in, have stayed warm in 0* weather.
Jan-08-2018 02:54 PM
bb_94401 wrote:
You might consider placing an electrical, far infrared radiant carbon thin film under your vinyl floor or carpet. It is 0.017" thick, in widths of 30, 40, 50, 60, 80 and 100 cm. Most common use is under wood floors. Koreans and Europeans use in floors, walls and ceilings. Just remember where it is, so a fasterner or drill doesn't go through it. :E
My plan is to intall it on the part of the wall surfaces and floor under the dinnette. Even though it runs on 120VAC, I figure on using it while I charge my batteries once they are out of the bulk phase of charging. Uses 200 W per meter squared film. Your inverter and battery bank could handle this.
Typical boiler based radiant heat systems inputs use:
105 - 115 F for water temp for wood floors (too high heat causes shrinkage due to drying)
85 - 105 F for tile / contrete floors (conducts heat well)
115 - 135 F for carpet (pad /carpet combination more an insulator)
Goal is to keep finished floor temp < 82 - 85 F. Suggests having thermostats that have temperature sensors that are located on the thin film to limit max temperature of floor as well as one for room temperature. Less regulated systems use lower W/m^2 films. Third generation films have a positive temperature coefficient which use less current when warm and less likely to overheat.
Websites to get an idea:
RexVa - XiCA carbon infared heating film
RexVA - Positive temperature coefficient heating film
Korea Heating EU
Fenix
Lots of Youtube videos showing installation
Carbon Heating Film
Key elements of the installation of infrared heating film
Infrared Underfloor Heating System - Installation
A little for surfing the web will find current suppliers in the US and eBay. Simple systems can even be found at Home Depot (Quiet warmth)
Jan-08-2018 02:52 PM
deltabravo wrote:
Rigid foam board insulation around the side walls where the camper sits between the wheel wells. That will help.
Jan-07-2018 07:10 PM
Jan-07-2018 05:19 PM
Jan-07-2018 04:13 PM
Jan-07-2018 02:56 PM
sleepy wrote:SidecarFlip wrote:
Sleepy..
I was perusing the Menards ad in the Sunday paper when I saw a heat ribbon designed to lay under engineered flooring to warm the floor in say a bathroom. While it was 110 volt, it was low wattage, less than 50 watt so you could run it on an inverter or genny too and it was thermostatically controlled and waterproof.
I may check them out for my floor myself for those chilly mornings.
Your idea is interesting... maybe even wrap up the sides of the area between the wheel wells. I’ll be watching.
I did look at the Menards add and other links on those pages.
Thanks
Jan-07-2018 02:36 PM
Jan-07-2018 01:45 PM
SidecarFlip wrote:
Sleepy..
Jan-07-2018 09:09 AM
deltabravo wrote:Lwiddis wrote:
Thick throw rugs (or two throw rugs-one on top the other) ... Easy to wash and/or replace too.
Throws rugs were the first upgrade I did in my camper.
Cheap and easy. Washable.
Done.
Jan-07-2018 06:32 AM
