Apr-29-2013 08:45 PM
May-05-2013 05:32 AM
May-03-2013 09:33 PM
May-03-2013 09:10 PM
May-03-2013 08:22 PM
May-01-2013 09:49 AM
Apr-30-2013 08:32 PM
Apr-30-2013 07:47 AM
Apr-30-2013 07:24 AM
69 Avion wrote:SuaveGato wrote:
So I had an idea (that may not be too original but it was to me) Since getting my TC, I have lost all of my room to take extra gear with me... shade canopy, BBQ, lawn chairs, ice chests, etc. I also need to find / build a platform to put my TC on when I want it off of the truck. So I thought, why not get a trailer like a Big Tex or similar that I can load all of my extra gear into and tow when I go camping, then when I get home, I can jack the camper off of the truck, slide the trailer under it and lower it onto the trailer! That way I have the support under it that is recommended, not just the jacks. And, I will be able to shuttle it around the yard too, if I need to move it out of the way.
Is this an obvious idea that everyone already does or is it a dumb idea that won't work for "X" reason? I guess my fears / concerns would be getting it on the trailer with the correct center of gravity, so I don't dump it. and I guess I could / should also strap it to the trailer with the mounts. Other than that ??? good or bad idea?
Thanks,
I actually built a trailer to haul my 1969 Avion C-11 on. I have now owned the Avion C-11 for 30 years and it has been in the family since new. We had built a yard trailer to store it on, years ago, but it wasn't for hauling it down the road. My wife gave me an option, build a trailer for the Avion C-11 or buy an Airstream Bambi. After looking at the Bambi, I decided to build the trailer. I now have a trailer that tows very well, even over freeway speeds, and is rated at 7,000#. It uses the same tires and wheels as my truck and hauls 80 gallons of water, 100# of LP, 20 gallons of gasoline along with one quad and a 30,000 btu external stove. The nice part is that I can take it off road when I want to since it doesn't sit low to the ground, and it can be used without the camper. This setup wasn't designed to take the camper off when I get to where I'm going. I don't even take the jacks with me. Besides, the old Avions weren't made to be used without support underneath them.
I also own a 34' Avion that probably won't get used again, because the C-11 trailer is much more suitable for boondocking.
http://www.airforums.com/forums/f417/new-member-restoring-1969-c11-90779.html
Apr-30-2013 07:16 AM
Thanks,
Apr-30-2013 04:29 AM
Apr-30-2013 03:51 AM
Apr-29-2013 11:23 PM
Apr-29-2013 09:07 PM
Apr-29-2013 08:55 PM
