- myredracerExplorer II
SoundGuy wrote:
That was my very first thought when I read the OP's post. I can't imagine how hard it is it climb a vertical RV ladder and get yourself up and over onto the roof. Could be even harder getting back down. I've used a ladder in house construction & maintenance a lot over the years and there's no way I'd ever use a fixed RV ladder. Only use a portable ladder that is leaned against the roof and here's why I say that:
Just an observation that no one else has mentioned BUT having climbed a trailer mounted ladder I find it FAR more difficult going straight up than on an incline when climbing a stand alone ladder propped against the trailer. ;)
Falls off ladders send 500 people to the ER every day in the US. Falls off ladders are the no. 1 cause of worker accidents here. Injuries can be severe and at the worst result in quadraplegia or death. Also, in a workplace, heights above 10' require fall restraint and many RVs are above that height on the roof surface. Climbing ladders and working on an RV roof can be very risky, even at the low heights involved.
OSHA has a one page summary on ladder safety here. Ladders also have load ratings ranging from 200 lbs for a type III to 375 lbs for a type IAAA. What load rating is an RV ladder?? Would you really trust the attachment method by a factory or a retrofit installation? If I were an RV manufacturer, I wouldn't even offer ladders due to the potential liability. An installation of a fixed ladder like RVs have would never be approved in a workplace setting.
I had a serious fall off a 6' step ladder 25 years ago because it collapsed under me and was standing a couple of rungs from the top and only fell 4-5 feet. I still have pain in one hip and enough to interfere with sleep sometimes and may eventually need a hip replacement. Ladders aren't something to take lightly.
Anyway, if a manufacturer offered a ladder as an option on a model line, I would think that the appropriate backing is placed in all units going down the production line. A retrofit would have attachment issues as mentioned by others. - westendExplorer
rbpru wrote:
Since both studs in that cavity are laid flat, I'm guessing they are backers for a shelving unit or closet.
Generally the short stud is there to anchor some inside component option down the line. That one looks like it was not used. - rbpruExplorer IIGenerally the short stud is there to anchor some inside component option down the line. That one looks like it was not used.
- legolasExplorer
SoundGuy wrote:
Here's another ...
... is that short stud (middle left) intentionally short or just stuck in because that's what the assembler had on hand. Good grief. :E
Its a good thing these guys work on rv's they'd never make it as even carpenters helpers - AtleeExplorer IIAnother agreement here. Back in the day, when I wasn in the US Navy,
vertical ladders I could navigate. Now many years later, and over my "playing" weight, I can't use a ladder. MY trailer has one, but I can't use it, I quickly found out.
But I had been insisting that any new RV would have a ladder, but at that point I hadn't tried to used one.
To the op, I definitely would not add a ladder to a trailer that didn't have one, because it's too easy to miss the vertical studs. Too much risk for too little reward.SoundGuy wrote:
Just an observation that no one else has mentioned BUT having climbed a trailer mounted ladder I find it FAR more difficult going straight up than on an incline when climbing a stand alone ladder propped against the trailer. ;) - nineoaks2004ExplorerI agree with MFL, some roofs are not made to be walked upon (states this on the owners manual.) I use a tall ladder when cleaning the roof on my Coleman, vent is easily reached from the ladder..
I have no intention of adding a ladder on the back when I really do not need it anyway - BarneySExplorer III
Agree! I always use a telescoping ladder when going up the rear. The built in ladder is too straight up and down and hard to climb for me. In fact, I have just about given up climbing any ladders anymore. My sons and grandsons are assigned those duties now. ;)
Barney - SoundGuyExplorerJust an observation that no one else has mentioned BUT having climbed a trailer mounted ladder I find it FAR more difficult going straight up than on an incline when climbing a stand alone ladder propped against the trailer. ;)
- rbpruExplorer IIIn order to clean my TT roof I wanted to walk on it. I emailed the manufacturer with the VIN number and they said "do not walk on the roof"
If you want to install a ladder contact the manufacturer. They will let you know if and where to attach it. - ADK_CamperExplorer
legolas wrote:
A ladder is great if your unit came with one. I don't have one but I got a really nice collapsible ladder at Camping World. Extends to 14 ft
when fully extended and collapses down to about 36" tall and fits quite well in the back of my pickup. I love it and there is always a need to check the roof.
I too have a telescoping (collapsible) ladder. I recommend one. It fits easily into the passthrough and comes in handy for lots of situations on and around the camper. I use it to occasionally get on the roof and to sweep off the slide at the end of each trip. I've also used it to hang a flag or light high on a tree.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
