Majja13's avatar
Majja13
Is a reflash of the ECM necessary
I have gotten a Check engine light a couple of times, and then soon after it goes off. I hae a mechanic pull the codes and it is saying that Back 1 and 2 O2 sensors are staring to fail. He suggested doing both sets at the same time, due to the fact I need to do an ECM flash after replacing them. Doe this sound correct to you all. Also could I do the swap as I know where they are and how to swap them and then just dive in to get the ECM portion if it is needed?
Thank you
