Is an old fantastic fan worth fixing?
Sheanhoxie
I have a fantastic fan that's 25 yrs old, but is still running like a champ. The plastic cover, and main body though, have seen better days.
There doesnt seem to be any replacement body parts for this old thing, but I might be able to patch the plastic parts that have chipped on the main body, and replace the garnish with a generic one.
Has anyone had luck repairing the old brittle plastic body that screws to the roof? These fans are definitely not cheap, so I'd love to salvage it.
If I should replace it, are these $300+ fans worth the price?
14 REPLIES 14
specta
No. Toss it in the garbage.
Kenny
1996 Jayco 376FB Eagle Series TT
1997 Jayco 246FB Eagle Series TT
1976 Ford F-250 4wd Mercury Marauder 410 - 4V
Regular cabs. The best looking trucks.
towpro
I seem to recall there is a life time warranty on the lid for the original fans. One blew off my dads motorhome, current Fantastic fan owners sent free cover.
I had modern ones installed in last 2 truck campers. I ended up replacing motors on both as they started to sound like crickets were in the motor. I still have some laying around and was going to experiment with drilling a hole to oil the motor bearings. But its the plastic that goes bad over the long haul that you might not be able to get.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
notsobigjoe
Nomad III
Nomad III
Sheanhoxie wrote:
Thanks ferndaleflyer, I have all of the original papers when the original owner first registered all of the products back in '96, including this fantastic fan. I'm going to reach out to Dometic (looks like they bought them out?) and see if they wanna replace it!
IN MY OPINION, Dometic customer service is fantastic. They're products on the other hand are not what they used to be. But if you can get a free one......
Sheanhoxie
ferndaleflyer
A couple of years ago mine quit and I went to my local RV parts place and he told me he would get a replacement. I was surprised when I picked up the new one and there was no charge as it was guaranteed for life
HMS_Beagle
I removed a new one put in a couple of years ago and replaced it with a Maxx Air. At this point, much better product.
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
Sheanhoxie
Thanks for the advice, I'll hang on to the motor. Most likely will be replacing the fan & vent though, upon closer inspection the body is pretty warped all around the edges with more cracks around the screw holes than I'd like.
notsobigjoe
Nomad III
Nomad III
The new ones are terrible. I switched to Max air.
Lwiddis
The new Fantasic fans ainโ€™t what they used to be. Fix it IMO.
I once bought an older used, but in great shape FF off Craigslist for 50 bucks.
Might be worth checking out, you never know what you'll find.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
monkey44
Nomad II
Nomad II
Practically any old part is worth salvaging and repairing today. Compare it to the worthless junk we can buy now that breaks when you look at it. Yes, salvage it if you can.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
Bedlam
Moderator
Moderator
I would buy a new one and keep this one for parts. Stay with the basic model that has the manual lift hatch and 3-position switches rather than the ones with sensors, remotes and lift motors.
mockturtle
The new ones are junk, IMO, compared to the old ones. If you can fix it, do so.
BTW, PPL often has parts you can't find anywhere else.
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
ScottG
That motor is smoother and more quiet than the new ones are. I would save it for that reason alone.
If nothing else, at least save the motor!
