โJan-22-2019 06:58 AM
โJan-24-2019 07:08 AM
Kayteg1 wrote:
With your camper weight you can't fool around, so buy the best.
I had 2 campers with Atwood jacks and 1 had swing brackets with holding notches only on 1 end, when other on both.
Even such small detail made big difference in stability.
Both campers i bought used and both come with brackets bent, what should give you idea that the part can be crucial
AnEv942 wrote:
If you have existing swing away bracket see recent thread to increase clearance..
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29818603.cfm
If you don't currently have swing away Atwood pn is 80687, however since Atwood jacks absorbed and discontinued by Lippert, Atwood parts are increasingly difficult to find (and then usually way over priced)
Rieco Titan brackets will work- one source
https://pantherrvproducts.com/rieco-titan-rsb-2a-swing-away-extension-bracket-kit-55721-white/
โJan-22-2019 08:56 AM
โJan-22-2019 08:17 AM
