starcraft69's avatar
starcraft69
Jack repair wood frame water damage 98 caribou
Well it was time to dig into this repair I have been putting off. Both rear jacks seem to have wood rot under the laminate the right one worse than the left. I started with the right side and you will see that I split the back wall in two sides at the door. also rebuild the wings. Here are some pics of the tear down and some repairs I have done.
I will post more as I go. I do have a question if anyone knows a good way to pull all the thin plywood off the back of the laminate so I can redo it. I will take pics of it tomorrow.
