peejaykay's avatar
peejaykay
Jayco Premier 284bhbe vs Outdoors RV Creekside 27BHS
Hi all,
It's down to these two trailers. THoughts or opinions on the two models mentioned below? I've seen the Creekside in person, its a great unit - solid frame design and fantastic insulation package & worksmanship. 7350 yellow sticker weight + 735 hitch. I haven't seen the Jayco in person yet. I am leaning towards the Outdoors RV unit because I think its a better built trailer.
Jayco 284BHBE
Unloaded Vehicle Weight (lbs) 6,605
Dry Hitch Weight (lbs) 630
Gross Vehicle Weight Rating (lbs) 9,250
Cargo Carrying Capacity (lbs) 2,645
http://www.jayco.com/products/travel-trailers/2015-eagle-travel-trailers/284bhbe/
Outdoors RV
Full Feature Dry Weight - Lbs.6935
Fresh Water Capacity (approx. gal)80
Tire Size ST225/75 15 Load RangeD
Exterior Length (approx. w / hitch)32'7"
LPG Capacity (approx. pounds)60
Gray Water Tank (approx. gallons)40/20
Black Water Tank (approx. gallons)40
Dry Hitch Weight (approx. Lbs.)660
Maximum Trailer Weight - Lbs.8800
Exterior Height 11'4" w/AC
Interior Height6'11"
http://www.outdoorsrvmfg.com/creekside/models/27BHS.php
