Jayco Premier 284bhbe vs Outdoors RV Creekside 27BHS
peejaykay
Hi all,
It's down to these two trailers. THoughts or opinions on the two models mentioned below? I've seen the Creekside in person, its a great unit - solid frame design and fantastic insulation package & worksmanship. 7350 yellow sticker weight + 735 hitch. I haven't seen the Jayco in person yet. I am leaning towards the Outdoors RV unit because I think its a better built trailer.
Jayco 284BHBE
Unloaded Vehicle Weight (lbs) 6,605
Dry Hitch Weight (lbs) 630
Gross Vehicle Weight Rating (lbs) 9,250
Cargo Carrying Capacity (lbs) 2,645
http://www.jayco.com/products/travel-trailers/2015-eagle-travel-trailers/284bhbe/
Outdoors RV
Full Feature Dry Weight - Lbs.6935
Fresh Water Capacity (approx. gal)80
Tire Size ST225/75 15 Load RangeD
Exterior Length (approx. w / hitch)32'7"
LPG Capacity (approx. pounds)60
Gray Water Tank (approx. gallons)40/20
Black Water Tank (approx. gallons)40
Dry Hitch Weight (approx. Lbs.)660
Maximum Trailer Weight - Lbs.8800
Exterior Height 11'4" w/AC
Interior Height6'11"
http://www.outdoorsrvmfg.com/creekside/models/27BHS.php
20 REPLIES 20
peejaykay
And I think the Outdoors RV model is less expensive than a comparably equipped Jayco Premier. Do you feel that one AC unit is sufficient?
sportsman16
I was in your shoes 4 months ago. Owned a 2004 Jayco Jayflight 27bh 10 years with no problems. We decided to upgrade and I was sure I wanted the Eagle 284bhbe. Went to my dealer who did not have one in stock and wasn't too interested in my trade. I did however see the same floorplan in the Jayflight model. Put off ordering the Eagle and stumbled upon the Outdoor Rv Creekside 27bh. Not knowing anything about Outdoor Rv I did some research and liked what I read. I located a Crrekside 27 BH on a dealers lot not far from my home. Visited the trailer and was impressed. HAd my Jayco dealer had the Eagle in stock and shown a little enthusiasm for my trade, I probably would have just bought the Jayco. I am glad they didn't. I preferred a couple small things on the Creekside such as the small factory solar panel, high pressure hose from tanks to run bbq, liked both sides open into the front bedroom, cable/power for dedicated front bedroom TV vs the swivel model in the Jayco, more counter space in Creekside vs extra pantry in Jayco. We purchased the Creekside 27 Bh back in May. Have spent 20 nights at 5 locations. Very pleased with the Creekside. Only problem to date was a piece of interior wood trim that started to come off. Fixed with a little gorilla glue. Don't think you can go wrong with either but am pleased with my Creekside.
carringb
One small note on ORV - My trailer turned out almost a foot and a half longer than the brochure said. (39' actual, 37.5' brochure). Not a big deal, except it won't fit in my driveway until a pour it a little longer.
Also, my actual water volume is 103 gallons per the yellow sticker (and even then I think it holds more). Brochure stated 80.
2014 ORV really big trailer
2015 Ford Focus ST
azwildcat99
1 more vote for the outdoor RV. It's a foot shorter which may make a difference in some NP campgrounds and if I'm reading it correctly it has 2 gray water tanks (20 galley and 40 shower?). If dry camping is in your future that would be a big selling point for me. The Jayco does have a nice color scheme though 🙂 and is very well-known.
Good luck with your choice.
2007 GMC Sierra 2500HD CCSB 4X4 D/A
2012 Heartland Prowler 27P BHS
Honda EU2000i
shelbyj
Thanks for posting this. I had never heard of outdoor rv before. I really like the 31kqbh floorplan. Dont usually see a front slide bedroom with a bunkhouse.
Shelby
2005 Jayco Jay Feather 26S
2002 Ford F-150 Supercrew 5.4
Kent, Wa
FrankShore
The OutdoorsRV is the walkaway winner in my opinion. Solid and quality built. I've been looking at them for a while now. They're heavier than the Lance but less weighty than the Arctic Fox I currently have. All in all, a good solid trailer!
Video #1
Video #2
2014 Creekside RV - Different Layout
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk båt - Dette må jeg se!
