Just pulled the trigger!
CampingN_C_
We just finalized the deal on a 2014 Jayco Jay Flight 32BHDS!!!!! I fought with the dealer all week over minor things, but in the end I think I did OK.
I wonder how the ol' 2500HD gasser will do with the heavier trailer ??
2018 Ram 3500 DRW CCLB Aisin 4.10 4x4
2018 Jayco Talon 413T
B&W Companion
21 REPLIES 21
wmoses
CampingN.C. wrote:
Those towing capacity numbers are simply inaccurate.
Trailer Life Towing Guides have been know for a misprint to two!
Maybe not inaccurate but misleading. When I saw that I wondered what the rear end was and since they likely did not have only one rear end ratio l figured that must be just for one of the ratios. In the more recent Guides they say what rear end gives what rating.
Glad to see that your truck has a higher capacity than 8000# but now that you mentioned your 9800# capacity I still think you have to watch your weight since you trailer's unladen weight already puts your truck at 80% of its rated towing capacity. My truck is supposedly good for 9600# but I would not want to go there, especially on anything but totally flat terrain.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
CampingN_C_
Those towing capacity numbers are simply inaccurate. Per owners manual towing cap for my truck is 9800lbs.
And that's because the 4L80E transmission holds it back.
Chevrolet made the 1500HD that year also. It was rated to pull 7,900 with the 3:73 rear end. They have it with a higher number than the 2500HD.
Look at the numbers for the same truck, but an EXT cab instead of CC. It shows a 10,600lb towing cap.
That's a 2,600lb difference going from a CC to a EC. That make sense to you?
2006 Towing Guide looks accurate.
B&W Companion
wmoses
Congrats on the new trailer. However based on the below you may soon be in the market for a new truck. ๐Ÿ˜ž
Based on the Trailer Life Towing Guides 2005
2500HD Crew Cab 6.0L V-8 - Towing Capacity 8000# / GCWR 16,000#
Now I don't know what towing capacity your owner's manual states, or your rear end ratio is capable of.
The truck itself has the following capacities per Nada Guides:
Curb Weight 5,760 lbs
Gross Vehicle Weight Rating 9,200 lbs
Max Payload 3,440 lbs
Based on Jayco's specs:
Unloaded Vehicle Weight (lbs) 7,590
Dry Hitch Weight (lbs) 870
Gross Vehicle Weight Rating (lbs) 9,975
Cargo Carrying Capacity (lbs) 2,385
Regards,
Wayne
_
DutchmenSport
I just looked up your new camper on the Internet. Nice camper. Just a word of caution. We love our Outback. But the inside stove is in the corner like your's is. When you use the stove, that corner will get very hot. The wood, the cover, the walls, everything.
Our's has a window behind the stove and sink. The blinds are aluminum Venetian. But the plastic stick to rotate the aluminum fins melted into a pretzel the first time we used the stove. Actually, we did not use the stove for cooking, we used it to help fast-heat the camper (which by the way, works very well when you need to heat up fast!).
But your model has the outside kitchen, so hopefully you'll not have a need to use the stove. When you do, just beware the walls around the stove get very hot!
Congrats on your new purchase ... by the way, I don't think you'll have any problems with your tow vehicle and this camper! Enjoy!
Edit: To shape the blind plastic stick back in place, I turned on all 3 burners and heated that corner again. When the plastic heated enough, I was able to just shape it straight again. You'd never know it once looked like a twisted pretzel!
Spappy
Congrats on the new trailer! Hopefully just in time for warmer weather. ๐Ÿ™‚
Spap
bobfears
Im pulling 7,000lbs with mine, you will be fine.
Goodpete
I've got a 31 foot Open Road Zander my Silverado 2500 DD pulls it quite nicely. A little slow up steep grades. I just bought mine last august.
