- Camper_Jeff___KNavigator
Kayteg1 wrote:
2oldman wrote:
Mikeryder wrote:
No.
Will a heater in the living space protect the water lines and tanks?
It will when you set the furnace to running fan only.
Leave the cabinet doors open and this heater will keep the pipes from freezing pending no electrical outage. The basement will be warmed a little through the warmth on the floor. If you setup a small fan to circulate warmed air into the basement, it will be protected from freezing. There are limitations to everything. The only for sure way to guarantee no freezing is to completely drain AND blow out the system. Perhaps pour RV antifreeze into the gray and black tanks. - Kayteg1Explorer II
2oldman wrote:
Mikeryder wrote:
No.
It will when you set the furnace to running fan only. - 2oldmanExplorer II
Mikeryder wrote:
No.
Will a heater in the living space protect the water lines and tanks? - work2muchExplorer
Mikeryder wrote:
Will a heater in the living space protect the water lines and tanks? I have a NL 9.5 and don’t thinck the heat will reach the basement.
If your basement isn't heated you could do what Arctic Fox did on our old camper. install a small electric fan that forced cabin air into the basement and a second hole with grill to allow circulation back into the cabin. You would need to cut a couple holes with a hole saw drill bit in appropriate places, find a small 12v fan and a grill. - Camper_Jeff___KNavigator
Leave cabinet doors open where pipes are and those spaces will be warmed. Can't guarantee the basement tanks. A furnace sometimes has a duct that blows into the basement to warm that area. I have an access door on the step I leave open to get some air flow into the basement. Never had a freeze yet. I do keep the TC filled loaded and ready to go all year. We generally have mild winters here but it does turn frozen a few times a year. - TiziExplorer
- MikeryderExplorerWill a heater in the living space protect the water lines and tanks? I have a NL 9.5 and don’t thinck the heat will reach the basement.
JimK-NY wrote:
My TC just does not need a 3 or 4 foot heater with a 1000 watts. Even in the coldest weather my 600 watt unit is way more than I need to maintain 70 degree heat in below freezing weather. If you need a big heater to maintain comfort at 45 degrees you might want to check for air leaks and areas where the insulation could be improved. I have sealed the wheel well areas and added a carpet. Both made large improvements in the warm and comfort.
Hi Jim,
Really the only difference between heaters wattage is how fast it will bring you up to the set temperature. Once at temperature the heater will cycle to maintain the temperature. My S&S is a 4 season camper so it is sealed and insulated well. I have also added 1" Styrofoam to the entire underside of the TC. - JimK-NYExplorer IIMy TC just does not need a 3 or 4 foot heater with a 1000 watts. Even in the coldest weather my 600 watt unit is way more than I need to maintain 70 degree heat in below freezing weather. If you need a big heater to maintain comfort at 45 degrees you might want to check for air leaks and areas where the insulation could be improved. I have sealed the wheel well areas and added a carpet. Both made large improvements in the warm and comfort.
2oldman wrote:
And that's where it stays, in the middle of the floor?
So far tonight, the heater has been under the dinette,
Across the room in front of the stove.
Now it is in front of the step.
I'm currently camped in front of a barn with electrical so I get to enjoy using the little portable heater. It's 70 inside and 45 with wind outside. Very cozy in here. It's 2:00 AM and been up getting some work done. The silent operation without fan noise makes for a good work environment with no distraction.
Remember, the primary reason for this heater is keeping the TC warm and dry when not in use. But as a side benefit, it is in real time working very nicely as a primary heater. It is not in the way at all and if it is, it's easy to move. Just grab the handle and place it where you aren't going to be. The space inside a truck camper is in a constant state of conflict with something. Something is always having to be moved. Being in a TC is like living in a Rubik's Cube sometimes.
SO yeah, It doesn't just sit in the middle of the floor. It's portable. It goes where you want it. There are no perfect solutions.
About Travel Trailer Group
44,055 PostsLatest Activity: Dec 23, 2025
