1buda's avatar
1buda
Last night of winter camping
Everything has been running ok for now. I've had no frozen water problems, heat in the TT. Now the shower is back up with water. What causes this?
HELP...
  • Well made it back home. Yes the black & gray water outlets were frozen. Took it to a local CG to drain both tanks and sure enough chunks of ice came out. Just a little bit of water is left in the shower and I'll pour hot water to see if it clears out.
    Thanks for all your help!!
    Maybe I'll try winter camping much later on when I get some experience under my belt.
  • If the holding tanks are empty(both black and grey - some showers drain into the black water tank), something is blocking the shower drain. Try pouring some hot water into the drain.
  • donn0128 wrote:
    Gray water tank full! Go outside and open the gray water drain valves. I assume your connected to full hookups?
    I just drained both tanks before finding the full of water.
  • Gray water tank full! Go outside and open the gray water drain valves. I assume your connected to full hookups?
