Racine96's avatar
Racine96
Leak
I think I am having a leak at the propane tanks, but small one. How do I test to check whether this is the case or not?
  • I just go by my nose. If I smell LP I change the fitting/hose as it's a quick and low cost repair. LP is too expensive to just loose LP to the open air.
  • Or... dish soap and water mixed in a cup and use a paint brush to brush it on the areas you want to test. Bubbles = leak.
  • If you don't have a sprayer, use a bowl of soap/water mixture and a rag.
  • robsouth wrote:
    Mix a sprayer with soapy water and spray all around. Look for any bubbles.
    I was going to suggest a candle.... :)
    Repo
  • Mix a sprayer with soapy water and spray all around. Look for any bubbles.
