Mote
Mar 29, 2016Explorer
leaking city water connection
when DE-winterizing the Lance yesterday I noticed that my city water connection is leaking. The pump was cycling on/off every 15 seconds so it's leaking pretty good.
I tried to see if I could pull it down enough to remove it from the outside but I can't. Do I have to pull the stove/oven out to get to it? That's the only way I see I can access it.
Or is there a way to rebuild it without removing it? For now I've just got a plug in it so it won't leak. We don't use the city water connection so I'll be okay until I can fix it.
