jefe_4x4
Apr 07, 2015Explorer
LED interior lighting for older TC
I searched here and searched other forums and found some conflicting info on incandescent 1141 to GRV Ba15s LED direct bulb replacement lighting. Most of the info is years old, with few recent posts. With a 10-pack of GRV Ba15s only $37US, I ordered a pack. At that price, what have I got to lose? They came within 24 hours (free shipping on Amazon) and installed them today. They were easy to install and installed 9 of them on the interior fixtures of our Lance. I thought the range hood light was the same, but Noh, it's a bayonet push on type. I turned them all on and it was plenty of light at about 1/8th the current draw of the original incandescents. A major drawback seems to be the narrow range of voltage at which they will work successfully. Nothing over 13 volts. At battery only voltage, I could feel no heat coming from the warm white GRV's. I plan to only use these while the truck is stopped, so I'm depending on the camper's electronic control center (as it was in 1998) to supply only that voltage or below. I should have metered the voltage at the pin before install. Some have experienced short life burn out with higher voltages. But, that was then and this is now. I'll report back on the long term result. One of the 'costs' of having an 18 yr. old relic.
jefe
jefe
