A couple of things to start.. Likely your jacks will be at full extension, or even up on blocks in order to remove or remount your camper. That can be OK when on pavement, but if you plan to remove the rig at your destination in a campground, you have to be extra careful with having a stable flat surface to put the jacks on.
The other item is your steps in. Some use platforms to put the lower step on, but even then, getting the scissor steps to work well when there is a lower back end to put the steps on is really difficult and dangerous at times. Family and dogs coming up and down sloping steps is not fun.
