Apr-10-2015 07:56 AM
Apr-16-2015 08:56 PM
Apr-16-2015 07:34 PM
Their a lot of brand name but not a lot of manufacturers.
Apr-15-2015 04:42 PM
Apr-14-2015 04:46 PM
Apr-14-2015 07:20 AM
Lowsuv wrote:
I also have a 10 x 10 garage door .
Looking around the lance 1575 will fit .
an airstream ( bambi ) will fit .
certain airstreams double axle will fit .
Apr-13-2015 08:32 PM
Apr-13-2015 07:49 AM
sewicamper wrote:
...snip....
I want my trailer to be as efficient (in all respects) as possible.
...snip......
Apr-13-2015 07:23 AM
Apr-13-2015 06:59 AM
Apr-13-2015 03:24 AM
hohenwald48 wrote:
I wouldn't ignore the dry weight. In order to view the yellow sticker I have to drive all over the place and take a look at each and every possible trailer. Using the published dry weight I can get a pretty good idea while sitting in my chair looking on the internet. Logically, a trailer with a lower dry weight will also have a lower configured weight assuming the weight of the options is likely about the same regardless of the trailer manufacturer.
Apr-12-2015 06:53 PM
Apr-12-2015 11:39 AM
Campfire Time wrote:
Welcome!
First lesson is to ignore the dry weight. It is a fictional number. No one tows a trailer at it's dry weight. Dry weight does not include factory installed options like AC, awning, oven, or even the spare tire as is the case with some manufacturers. There is a yellow sticker on the driver side of the trailer that lists the "shipped" weight, which is always higher than the advertised dry weight.
Apr-11-2015 09:51 PM
SilverEscape wrote:
I remenered one I found a year or two ago. Livin Lite Camplite 21 BHS. Meets all of your criteria except for the heated tanks. For the enclosed underbelly, it looks like the option is spray on insulation. So you might want to call Livin Lite and see if it what they do would work for you. And ask them about heated tank options, they may be able to offer a suggestion.
https://www.livinlite.com/camplite21bhs-overview.php
Apr-10-2015 04:52 PM
