dennych1
Aug 21, 2020Explorer
Lithium batteries
Who has installed lithium batteries but didn’t change your charging from truck to camper batteries by adding DC to DC charger
pianotuna wrote:mbloof wrote:pianotuna wrote:
Since Li don't want to be taken to 100% I can't see why a dc to DC booster would be particularly useful.
Since when? Can you quote a source for that information?
The Battleborn battery I own and even the DIY LiFePo4 cells I bought along a with proper BMS have no issue with being charged to 100%.
- Mark0.
Many many many sources.
Some BMS systems have the 90% set to read as fully charged. Battleborn might be one of them.
The ideal is 40% to 90% for most Li chemistries.
They tolerate 20% state of charge well. But lifespan may be shorter.
Here is a source that suggest maximum of 80% SOC:
https://electrek.co/2018/05/04/are-you-killing-your-lithium-batteries/
srschang wrote:
I have no need for truck charging for my 2 100ah Battleborn batteries. The 400w of solar keep them charged up. In fact, I disconnected the truck charging wire at the camper converter, I wasn't sure how the AGM truck batteries would handle the 14.6v from the converter when I have the camper plugged in.
NRALIFR wrote:
Srschang, is the changing wire to the camper on your truck not switched by the ignition? Even if it’s not, why would your trucks AGM’s not like 14.6? The AGM charging specs I’ve looked at seem to like up to about 14.9.
That’s assuming that the 14.6 from the camper is even reaching the truck batteries, that is. There’s about 20 or so feet of wire between the camper converter and the truck batteries on a crew cab pickup, so the voltage drop is going to be considerable. At any rate, a few minutes with a volt meter would tell you.
For me, having multiple ways of recharging the camper battery is a good thing. I’m not always in a developed campground, or even in an environment where solar can be totally relied on. It would be nice to have a panel or two on the roof, but the DC-DC charger isn’t dependent on the sun. If I ever get around to adding a solar panel, I’ll just connect it to the solar input on the Redarc.
