Load Range E tire pressure: how do you keep them up?
Whangler
Soon, I will have my newer trailer, a 2014 Arctic Fox 25r. The first thing I do will be to take it to Discount Tire and remove the GYM's and put on LRE Maxxis 8008's.
My old trailer ran 14" LRC tires inflated to 50psi max. Even getting those up to pressure was sometimes difficult if I had to air up on the road using lousy gas station air. They held pressure very well, but once or twice I needed to bring them up a few lbs.
Now, these new LRE's run at 80psi. I reckon truck stop compressors will do the job but like gas stations, they're not always easily accessible. Do any of y'all use 12v tankless compressors when you're afield? If so, I'd like a recommendation for a good one. IF, that is you think it necessary.
Thanks,
Mars
31 REPLIES 31
stratcat
I'm a retired long haul trucker.(12 years owner) I'm in the habit to check tire pressure when ever I move the trailer. Always check them when the sun is not shinning on them for a period of time. normally have to add a few pounds each time. No my tires do not have leaks. tires will loose a couple pounds over a few weeks. Pressure will also change with temps, altitude, and driving speeds. A soft tire will come apart internally over time due to flex of the plys. suggest a few of you need to talk to your tire dealer about adding air. When you pay $600. for one tire you learn to take care and check air pressure.
Those of you that say you don't have to add air, are you using nitrogen??? and if so don't add compressed air to those tires, you will have problems...
CavemanCharlie
To the OP , if you drive a little further off of the interstate almost any automotive repair shop in any town will have a big enough air compressor to fill up you tires should they get low.
I fill my tires once a year and the hold up all year long.
GrandpaKip
We always have our HF el cheapo compressor( the one with the battery clips ) and TPMS. While traveling, I check the pressure before leaving in the morning and visual/touch check every stop.
The Maxxis have never lost pressure except for large temp drop and extreme altitude change in the last 3 years. I would really dislike being without either of the above.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Community Alumni
Not applicable
If you're losing notable amounts of pressure from pressure checks, even frequent ones, then you're doing it wrong.
93Cobra2771
Even better - get a TPMS so you aren't losing all that air checking them...
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
schlep1967
Your tire pressure will change 1-2 lbs for every 10 degrees of temp change. Check them when it is 40 degrees in the morning and then check them after the sun shines on them and it get up to 80 degrees in the afternoon just to prove it to yourself. This is why they have you check pressures when the tires are cold. If you inflate them when they are at their coldest state for the day they will never be under-inflated.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
wanderingbob
I often wonder if the person that we pay to mount our tires ever looks at rim cleanliness or condition . Seems to me that a gob of something at rim seal might cause slow leaks .
myredracer
Thanks,
Mars
If you are in Or., chances are you will see enough elevation and/or temperature changes often enough that you should be routinely checking psi. Some, like me, check pressure before heading off on each leg of a trip. Anything can happen and you don't want a blowout or slow leak. If you don't have one, a TPMS is a good idea.
We have a Viair 12 volt compressor that has their highest cfm in a portable (2.3 cfm). Viair compressors are very well made but are not inexpensive. A portable 120 volt compressor is an option depending on where you camp. Won't be any good if stuck out on a lonely road somewhere or before the end of quiet hours in a CG. If looking at other 12 volt compressors, look at their cfm, psi and duty cycle ratings closely. The Q Industries MV-50 gets good reviews and looks like a facsimile of Viair. I bought a Viair inflator gauge but ended up returning it because it is cheaply made and has poor performance - it also leaked like a sieve from the rear of it. There are much better inflators out there or use a tire chuck and hand-held digital gauge. An automatic 12 volt compressor is better IMO because you don't have to switch it off when moving from tire to tire. I installed a marine watertight plug & connector so I don't have to take the top off the battery box.
Community Alumni
Not applicable
Whangler wrote:
Thanks everybody. My last maxxis's didn't lose much, just down 1-2psi from 50 every 6 months or so. That said, my cheapo harbor freight 3 gallon compressor doesn't exactly make short work of topping them off. I can't imagine how it would labor to get from 77-80psi :-0
Rather than getting a dc compressor, maybe I'll just get a stronger one for home and keep my fingers crossed I don't need to air up afield.
It would still make sense to carry a DC powered air compressor for when you're not at home. They may not be 5 CFM 120v air compressors that can top off tires in literally seconds, but they get the job done, weigh next to nothing, and take up very little space. You don't want to get into a situation where the tires have lost air, but you need to tow the trailer for several, maybe even dozens, of miles to find a filling station.
DC compressors will take minutes to fill up a tire from 0 to 80 PSI, but rarely would you ever do so. If your tire went down to 0 PSI then it would be a better idea to have it removed and inspected rather than trying to refill it. Most of the time you would be topping off the tires, somewhere around 1-10 PSI.
I have the compressor below and 65 PSI tires on the trailer. It doesn't take long to add 10 PSI to the tires, maybe a little over a minute. Performing the same action in your case (@70 PSI) wouldn't add much time.
When you're looking at DC air compressors look for ones that have battery clips instead of the 12v socket connector. The units with battery clips are usually more powerful and since you can power it from virtually any battery, you have more options to power it. Also pay attention to the CFM rating of the pump, the higher the better. Forget about anything that's less than 1 CFM.
Harbor Freight 150 PSI Compressor
93Cobra2771
2012Coleman wrote:
Mandalay Parr wrote:
I fill my once a year. A few pounds over so they last for a year.
Never have to add inbetween.
Weigh your trailer then go by the tire chart for the correct amount.
80 may be too high.???
I'm finding this hard to believe. I air up my Maxxis 8008 tires using my air compressor. I check them every 3-4 weeks, and they are always 5-10 lbs low.
Do you run a TPMS? If so, the sensors may be flexing enough (while driving) to cause the stems to leak. Especially if you don't have metal stems.
Otherwise, something is wrong, as that is WAY to much loss in 3-4 weeks.
I typically hit mine at the beginning of the season and it lasts the rest of the season until colder weather hits.
Richard White
Hensley Arrow
Atlee
I've been carrying an air compressor (don't remember what size the air tank is off hand) for over two years now. In fact, carried it with me when we went on our coast to coast trip in early 2014. Only needed it twice in all this time, both on the trip out west. Once in Death Valley, I needed to add about 4 pounds to a trailer tire, and once in the Mohave Desert at a BLM off road recreation area to air up the rear tires of a guy who worked in the film, TV, commercial business of supplying animals. His rear wheels of his ATV were flat.
Thanks,
Mars
Erroll, Mary
2021 Coachmen Freedom Express 20SE
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
Equal-i-zer Hitch
Atlee
My Maxxis hold air for months at a time, what can I say?
Good tires will hold air, what can I say?
Erroll, Mary
Equal-i-zer Hitch
bankmule66
I find that pressure in trailer tires as well as TV tires and wife's car tires vary with the temperature
MarkTwain
X2, I have used Good Year LT "G" rated tires for the last 10 years and GY LT "E" rated 10 years before that. My 5th wheel weighs 12K+ when loaded going down the road. Have not had 1 tire problem. GY stands behind the warranty on their tires. My 1st TT came with GY "D" rated tires and I blew them out within 1 year. GY replaced all tires and paid for the damage to my trailer--No cost to me! BUT, I never run without METAL STEMS.
