- mkasnerExplorerSounds like a typical Arctic Fox :) Unless you find one that was stored in a garage its entire life, you'll find more of the above than the garage finds. For ones that were garaged, the owner will want a premium. Enjoy your search, there is a camper out there for you
- Grit_dogNavigatorToo bad. That one wasn’t taken care of it sounds like. Good thing you spotted the issues.
Agree, we like the layout too. About the most you can squeeze into a short bed truck camper. - jimh406Explorer IIISounds like a good call to skip this one.
- harley4275ExplorerWell , after looking at this camper , I noticed alot of delam on the front under the window and on both sides of the cab over along thr lower trim . Also under the cabover the whole thing was loose and could push up and down easily . There was even 3 little holes drilled evenly under the front of cabover and when I pushed up near them ....water came out... Looks like everything in front of the front jacks was wet...
Even the ladder on the back was not screwed into any meat anymore. Was good up top but middle was loose.
Both sides of the matterss inside the compartments were damp with rotton wood veneer ...
Of course the wings were punky and the left side storage bottom of the wing area was squishy...
Too bad as was a great layout with genny ,ac ,4 season pkg and every option .
Think I will stay clear ... Thanks for all the replies. - davemhughesExplorerLurking, thanks for the question and answers as we are looking at a used Host and a used AF. So well will plan to check these even though we will not see either until we decide to buy one and travel there (500 miles) in opposite directions.
- harley4275ExplorerThx for the replies , just absorbing it all. Did not know the 03 was wood frame . Willbe seeing it next week and will be unscrewing a few trin screws and inserting a thin wire to see if it is solid. I know my Lance was rotted under the side bedroom windows.
- Grit_dogNavigator
mkasner wrote:
Yes, nothing wrong with buying a camper that needs some work either and is a great way to learn about how your camper is put together and how to fix
Totally, as long as you have more time than budget, and even at that I wouldn't want to take on structural damage. Maybe some rotted wings or something, but not in the skeleton.
One thing I think helps, is if the wings aren't rotted yet, I sealed all the seams and painted or under coated that whole area. It is very susceptible to moisture from road spray. - Grit_dogNavigator
burningman wrote:
I’ve also been eyeing an Arctic Fox for quite a while.
The ‘05 and later “Silver Fox” has the aluminum frame, if that’s an important point for you.
I targeted that for our first camper. Got the 05 in 2013. Sold it before we left AK and moved back to the L48 only because it was worth more up there, it was a fine camper. No issues at all, except it had a slight leak, I think from clearance lights that ran down to bottom edge of cab over part. Drilled a couple holes to get the water out and it quit leaking after I re sealed.
Bought the 03 as a replacement and the wood frame has not been an issue thus far. Camper looks, acts and feels the same. IMO, the most stress is high winds and large bumps while traveling and while we don't use it a lot, I'm not gentle with it. Off road, potholes, washboards, 75mph in heavy winds. I'm happy with how it's holding up as well.
It doesn't feel any heavier and the aluminum frame is wrapped with wood anyway.
Given the choice I'd go aluminum, but I wouldn't turn down a wood one to save a buck as long as it was solid.
I look at it this way. The old AFs are very popular up here and even the ratty looking old ones that are left out in the rain don't ever seem to be sagging or structurally compromised. - mkasnerExplorerYes, nothing wrong with buying a camper that needs some work either and is a great way to learn about how your camper is put together and how to fix
- burningmanExplorer III’ve also been eyeing an Arctic Fox for quite a while.
About Travel Trailer Group
44,028 PostsLatest Activity: Mar 15, 2025
