Hi MouthyPuppy,
Congrats on your new camper, it sounds like you have a good-sized project ahead of you.
As was said by the other members, the camper did not come with a detail-level manual, they are too expensive to make a manual as detailed as an auto or even a lawn mower. Find the make and model of your power center and Google that brand and model. Being a 97, you may find that model or even company may no longer be in business and even if that model is still made, they were not very good battery chargers back then. More like battery killers with overboiling them.
If you want help buying a new power converter, see this website. Best Converter.com. They specialize in helping upgrade and replace old dead power converters and they really know their stuff.
https://www.bestconverter.comTo the rest of your questions, each question is a topic all by itself. Suggest if you are going to post the question here on RV.net to ask each one as a topic of its own. Also, learn how to use the advanced search feature on the forum. All those topics have been covered, maybe not on your brand and model, but on other campers to learn from. Search out, and read then ask what you can't find. You can ask better questions then.
There are many folks here on RV net that have restored older campers. In my case, I have restored mainly the Sunline brands of campers. They were built in a simar fashion to the older Shasta's. If yours looks like this Shasta
https://www.parkwayrvcenter.com/product/used-1997-shasta-rvs-lt-245-1195269-29 That is what they nickname a stick and tin-built camper. Odds are high that yours has water damage in it. Learn how they built are and how they leak "before" you start taking them apart. Most just tear into the inside thinking campers are built like a house, but they are not. And they make a lot of extra work to do. That style camper is built from the outside in. I do most all my restoring work by taking the camper apart from the outside first, then tearing it into the wallboard as needed. Those older campers can be totally rebuilt and sealed up better than many brand-new ones. But, it will take a lot of time to do it. Maybe even years pending how far you want to restore it and how much time you have to work on it.
Hope this helps and good luck.
John
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
