- Anmacc2ExplorerI too have a keystone. My bumper would not support a carrier like that. Might want to check if yours is?
- is_it_friday_yeExplorerHave a local welding shop make one for you. Take your trailer to them and have them weld it to the frame.
- LynnmorExplorer
That may not be the answer. If you have a frame like mine, it can barely handle a second coat of paint. - beemerphile1ExplorerI like the fact that it is connected to the arms that the bumper is supported by. Probably some of the weight is on the bumper but not most of it. Many people have learned the hard way that the bumper cannot support additional weight.
- bobndotExplorer III have seen them on fivers but not so much on TT's .
Fiver frames seem to be heavier and the TV on a fiver carries hitch weight over its rear axle opposed to the end of its bumper hitch with a TT.
I'm assuming that you have already looked into the weight distribution calculations re: adding weight to the rear effecting tongue weight on the TV .
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24730980/print/true.cfm
If weight distribution on the hitch is not an issue on your TT , I would think a frame mount fabrication would be a more solid necessary application. See pics in below link.
http://www.modmyrv.com/2008/06/28/rv-bumper-mount-cargo-carrier - hohenwald48ExplorerHere's what Lippert offers
http://store.lci1.com/products/storage-towing-and-security?___store=english&p=6 - 1L243Explorer III understand excessive weight can be an issue on the back of the trailer. What I am looking for is a large platform so I can carry a folding trike bicycle and a regular bicycle. Weight will not be over 75lbs...not including the carrier...
The Lippert link provided is the carrier. - goducks10ExplorerArrg. Can't get pick to post.
Anyway. I made two receiver brackets that bolt/weld to the bumper and frame. Then made a slide in rack for two bikes. Been on the trailer for 3 seasons and 10,000 miles.
I will try and get a pic posted. - goducks10Explorer
- HuntindogExplorerThat is very similar to the one that came on my 2010 Sabre... Even the yellow sticker which states a capacity of 450#. This design doesn't rely on the bumper for support. It is bolted right to the frame. The rack portion is changed from what mine has, but the rest is identical. Propbably an evolution of the design.
I see no reason why this rack could not work on other brand TTs that have a suitable frame to mount to.... Not sure how you would determine a safe weight rating though. Just because the rack is good for 450#, doesn't mean that you can bolt it on any TT and expect it to be able to carry that much.
I absolutly love mine. I think it is the best rack in the buisiness.
I even mounted a small deep freezer on one side of it for my extended boondocking trips.
I made one mod to it. The hitch pins were a somewhat loose fit, allowing some movement of the rack up and down. This became a problem with the freezer, as it would hit the ladder when going over roads that had a lot of frost heave bumps. So I bought the next size up hitch pins and drilled out the holes for a perfect fit.
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 20, 2025
