- The_OwlExplorerMy Nash 25c also had the generator prep. Never installed one but the connections and compartment were there.
- BizmarksMomExplorer
TurnThePage wrote:
Yep! My Nash 22h had a generator option.
Northwood Manufacturing builds Nash and Arctic Fox trailers with generators. - dadwolf2ExplorerArctic Fox 22G, 25R and 28F are generator ready.
- Nash 17K and 22H can be had with a generator... last time I looked at them anyway.
Nash and Arctic Fox
Easiest (fastest) way to see which models are generator capable is to download the brochure - HuntindogExplorerWhat I consider a major drawback is the the only genset TTs run of of the propane supply.
THs generally use gasoline. - Sandia_ManExplorer III don't know of any off hand, our TT TH came with an Onan onboard that was installed midship from the factory. Never an issue and we put over 1200 hours with more than half of those hours running our AC during the heat of the day. Still runs great but we picked up a Champion inverter genny with remote start as the Onan was major overkill most of the time.
About the only time we use the Onan is to exercise it or running the AC while traveling down the road on hot days that way our rig is nice and cool upon arriving to our destination. We just wheel the Champion down the ramp or out the door and plug in our shore cord. Simply press the remote to turn on or off, easily runs our AC unit, even on eco-mode and at high elevations.
Since most onboard gennies for TT TH's our installed in the pass-through basement storage, any TT with ample enough space can have a genny prep done by the manufacturer or aftermarket by the dealer. Of course genny bay door needs to be vented, some will open their generator compartment doors when they experience overheating, ours is labeled to never open door when running.
The great thing about the Onan is it could easily run for a couple of days straight since it had it's own 30 gallon tank, our Champion inverter genny can go more than a dozen hours on it's under 2 gallon tank, roughly 7 hours when running the AC which usually is enough per day unless it is humid as well. We are looking for a TT suited for couples, our Champion will sure come in handy. - TurnThePageExplorerNorthwood Manufacturing builds Nash and Arctic Fox trailers with generators.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 26, 2025
