Wind River wrote:
Are your batteries fully charged? Low voltage will cause the detector to chirp.
Yes. I will also add a problem I found with mine after purchasing a 3 year old used TT.
Previous owner: Some liquid soap had spilled just behind where the LP detector was installed in the kitchen cabinet. Since it did not appear the soap was ever cleaned up, the soap proceeded to corrode the wire connections at the LP detector. Jump forward to me having an issue with the LP detector periodically going off.
When I removed the detector to inspect it, one of the wires was only held on with a few wire strands. The few wire strands that remained was not even close to allow the proper AMPs to flow to the detector, causing an issue where the detector would periodically go off but did not indicate LP detection. I cleaned up all of the liquid soap and then re-spliced the connections and have not had an issue since.
Point of the story is yes, low voltage will cause a LP detector to periodically go off even without LP detection. I believe the manual states low voltage will cause this occurrence.
