โJan-29-2014 01:42 PM
โFeb-03-2014 03:31 AM
jus2shy wrote:
I own a 3500 SRW, Crew Cab Short bed 68RFE with the Cummins. My maximum payload is roughly 3,800 lbs according to the sticker. GVWR is 11,700 IIRC. I think you may be at/near the limit of payload if you use the 20% rule. Then you'd have no room for anything but yourself on the truck.
โFeb-02-2014 04:00 PM
โJan-31-2014 04:55 PM
โJan-31-2014 06:33 AM
john&bet wrote:
I will relate a talk I had a few years ago with a fellow who had a Travel Supreme triple axel 5th that they were full timing in. He pulled in next to me and we were talking about his set up. The truck was an MDT and his trailer had a GVW of 18k+ that he had towed with a 3500 dully. The engine performed real well but the rest of the truck was lacking in tires and braking and general comfortable feel. He was much happier after the up grade in truck. Just for your consideration.
โJan-31-2014 06:28 AM
โJan-31-2014 05:40 AM
โJan-30-2014 08:13 AM
โJan-30-2014 08:07 AM
โJan-29-2014 11:03 PM
โJan-29-2014 07:09 PM
DarrellQ2001 wrote:
I'm going to buy a new 5th wheel this spring and I know I must upgrade my truck also. I like the Excel 37IKE but it has a GVW of 18,700 and I hate DRW trucks. Is there any make of SRW that would safely handle this trailer?
โJan-29-2014 06:44 PM
hmknightnc wrote:
As others have said you are limited by tire capacity with a SRW 1 Ton truck. It highly depends on the truck and gear you have in the truck but as a general rule with a 1 Ton SRW you should stay below 14k# GVWR of a FW, for a 3/4 Ton you are looking at no more than 12k# GVWR FW. The trailer you are looking at is squarely in Dually country
โJan-29-2014 06:40 PM
john&bet wrote:or at least 450/550 territory.
You may even be pushing MDT area.
โJan-29-2014 05:19 PM
โJan-29-2014 04:51 PM
Nutinelse2do wrote:
HDT
