fmattox73
May 03, 2014Explorer
Mobility Scooter Carrier
Continuation of Receiver Article:
The Cargo Carrier and Ramp platform showed up and after unpacking and some minor assembly I ran into a problem.
The Tube would not fit into the 2" receiver. The reason why, was that the tube was rounded on the top, but mostly square
across the bottom
Her's the original picture and then I'll make it larger to show what I had to do.
As you can see, I had to file the squarish corner down a bit to make it fit into the receiver tube.
The left rear view with the carrier in place.
The right rear view.
So the project is almost finished. Right now I'm deciding if I want to shorten the tongue on the carrier to make it fit
a little closer.
Frank Mattox
Goodyear, Az.
across the bottom
a little closer.
Frank Mattox
Goodyear, Az.
