Moki Dugway, can I do it?
2manydogs
Leaving Cortez Co. for destinations in the west, was just wondering if it is doable for us being what we are, a long bed Ford DRW towing a 14 ft. utility cargo trailer on a 42 inch extension which enables us good maneuverability for some very tight spots. Our truck camper is a Arctic Fox 992 on a 2012 Ford DRW 6.7 diesel.
20 REPLIES 20
jimh406
I had to look up what it was, but this is what I found. Sounds like you should leave the camper and trailer at a campground or RV park.
https://bluffutah.org/mokey-dugway-muley-point/
The State of Utah recommends that only vehicles less than 28 feet and 10,000 pounds attempt to negotiate the dugway. The remainder of US-261 is paved.
TenOC
Muley Point is also a good free boondocking camping. The road to Muley point is somewhat washboard but worth the drive.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
fpoole
Yeah, should be fine...
I'm in a 10' Flatbed and while I wasn't towing at the time, I was surprised at just how easy it was compared to all the warnings.. just have to make one or two WIDE turns.. and since your there, don't forget the lookout point at the time. There's a dirt road, fairly nice at the time, although washboarded.. but slow n easy will get you there.. a little tight turning around but should be ok...
Moki dugway
Muley Point
Gooseneck SP
Do a Triple Crown and stay at Gooseneck for a night or two..
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10’ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow N’ Go, E-Bike
RS1 Buggy
frank
Pooles website
jmckelvy
You should be OK however it will be a good pull with the load you have. The road was used originally for 18 wheelers hauling uranium ore so it is much wider than I expected and the switchbacks are not real tight.
I came down it in my Jeep Cherokee so years ago.
06 RAM 3500,Dually,CTD,Auto(ATS Stage 1),QC,4X4,PacBrake,Spyntec Freespin Hubs,60 Gal Titan Tank,EFI Live, Line-X,Torklifts and SuperHitch,Fastguns
2013 Arctic Fox 990, 275 Watts Solar, 2 Grp 31 AGMs
US Navy 1964-1968, 2-Tour Vietnam Vet
Bumpyroad
sure you can do it. I didn't enjoy myself driving up it in my toad however.
bumpy
Lwiddis
Does the state restrict length? If not, I go. Did CA 4 once with a trailer. Interesting.
