Flashman's avatar
Flashman
Jun 06, 2018
Moving the jacks
This has probably been discussed before but I couldn't find it with a simple search.
I boon-dock a lot and when going over an uneven road I have come close to scrapping the rear stabilizer jacks.
I thought of some of the swing down type instead of the scissor jacks . Then I read somewhere? that another, cheaper solution is to move the jacks forward towards the tires - this would reduce the hanging down effect when going through a dip or over a hump.
Any opinions?
  • Flashman wrote:
    On my toy hauler the plumbing is forward. The spare tire would be the next thing to hit.
    In my experience the rear of the trailer is where I get hung up. The extra 4 to 5 inches clearance provided by moving the Jacks forward would help.
    That’s what I would do. Can’t see that hurting stability a bit.
  • On my toy hauler the plumbing is forward. The spare tire would be the next thing to hit.
  • Huntindog wrote:
    I have raised every TT I owned.
    My present TT is 34'. It has been raised with lift blocks, a thicker spring pak, and larger tires.
    I go down some pretty bad roads with this setup. My jacks have never given me a problem, so I have never considered moving them.
    Personally, I am more concerned about the plumbing clearance than the jacks.
    Very good point on plumbing.
  • Seems to me moving them eight to twelve inches forward would help a lot. Mine is 36’ long and when it drags it’s usually just the last inch or so that doesn’t quite clear. I think it would be worth a try. I don’t see where it would hurt anything if there are no tanks or utility lines etc. in the way.
  • valhalla360 wrote:
    The further forward you move them the better they will be clearing dips but the worse they will be at stabilizing.
    A simple option is to remove them and use simple aluminum jack stands.
    Too much to mess with. I need a quick and simple.
  • Move the jacks towards the tires, it will actually allow you to put more weight on them so movement will not be more of a problem.
  • The further forward you move them the better they will be clearing dips but the worse they will be at stabilizing.
  • I have raised every TT I owned.
