BobsYourUncle
Jan 10, 2022Nomad
Don't rule out the alternator.
While it may appear fine, charge well etc, a bad diode in the rectifier bridge can cause an undetectable "leakage".
I had that once in an old car. The battery would run flat after sitting a few days. I had a dickens of a time figuring it out until I disconnected the alternator and found no drain with it unplugged, and the main battery wire removed. Took it apart, replaced the rectifier assembly - end of problem.
44,025 PostsLatest Activity: Feb 26, 2025
